Wide Trims For Can Lights? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 11:47 AM   #1
j_sun's Avatar
Wide trims for can lights?
Hi,
I just installed a drywall ceiling in my kitchen with 7 6" can lights. I didn't cut the holes quite right and had to repair most of them. Problem is that you can still see my "repairs" sticking out around the trim rings (standard $10 ones from Lowes)
Rather than go through more patching, sanding and painting, I'd like to just get some rings with a wider lip to cover more of the area. Lowes says they don't carry any rings with a wider lip. Only the 7.25" diameter ones.
Does anyone know where I can get reasonably priced trims with a wider lip? Even something with an 8.25" diameter will cover all my mistakes.
Thanks,
Jason
j_sun is offline   Reply With Quote
Old 03-15-2013, 01:28 PM   #2
Rewards Points: 676
That sucks. I had a few slips with my rotary tool when cutting around my can lights in the basement. I wonder if the wider lips/brims will look weird. I would recommend just doing the further required patching/sanding so that things will look "right" in the end.
B
Beepster is offline   Reply With Quote
Old 03-15-2013, 02:03 PM   #3
funfool's Avatar
Rewards Points: 534
I would have to think they are available somewhere? Maybe if you order something on line as a decorative item.
I have never seem them local myself, and they do not give you much room for a mistake when cutting out the drywall.
I have always just use hot mud and repaired the mistake.
funfool is offline   Reply With Quote
Old 03-15-2013, 02:28 PM   #4
j_sun's Avatar
Hi Fun,
I have seen reference to "hot mud" in many posts but I'm not familiar with it. What is it, why use it and where can I get it?
Thanks,
Jason
Tags
can light , recessed , trim
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 07:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 06:28 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
