Why Apply Texture To Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 09:07 PM   #1
Why apply texture to drywall?
I'm in the process of completely gutting my upstairs bathroom. I'm just a novice DIYer and having a great time doing this, learning a lot. I installed my first piece of drywall today and had no issues, finishing a wall.
I see a lot of information about "how to apply texture" but can't really find anything on WHY I should apply texture. I would prefer to keep my walls smooth, but I want to make sure there isn't a reason other than looks to apply texture to the walls.
So, why should I apply texture to my bathroom walls?
Also, the ceiling was popcorn-ed but I removed it, so it as well, is smooth right now.
acschnabel is offline   Reply With Quote
Old 03-23-2011, 09:21 PM   #2
I can tie my own shoes
algored2deth's Avatar
Nothing says you have to apply texture anywhere. It is all up to you. For a bathroom, I would think a smooth ceiling finish is a good idea. Easier to clean to remove moisture issues. I have seen textured walls in bathrooms done with sponges or similar. All done for aesthetics IMO. Perhaps others here have more insight as to why textures are applied.
algored2deth is offline   Reply With Quote
Old 03-23-2011, 10:08 PM   #3
Old School
Willie T's Avatar
I almost never texture bathrooms or kitchens. Almost always smooth finishes (Level 5) on those two rooms. A bit more work, but much easier to maintain.
Willie T
Old 03-24-2011, 07:35 AM   #4
Thanks Willie.. You've made me read about the levels of finishing drywall! Should have done that before going to bed instead of in the morning waking up. Wasn't planning on doing the skim coat on the entire surface, but will consider it now.
Old 03-24-2011, 09:15 AM   #5
I think the most common reason why people use texture is because it's easier and faster (read: cheaper) than making smooth joints. i.e., it's a shortcut.
pyper is offline   Reply With Quote
Old 03-24-2011, 09:50 AM   #6
If texture isn't applied or skimming isn't done then you will be able to see the difference in texture between the face paper of the sheetrock and the smooth none existence texture of the mud on the seams, screw(or nails), metal corners and angles. Many years ago, virgin paper was used on the sheetrock and it had a more smooth surface, but now it is all recycled paper and it is more coarse than it used to be. You wouldn't think that you could see the difference but with light coming across the surface it will definitely show. By textureing the surface, it evens everything up giving you a new surface that will blend the paper with the mud. Now, it is extremely important to use a good primer before texturing. The reason being is that it will let the texture all dry the same to make it more uniform. Without priming, the texture can shrink more on the mudded areas making it smaller than the texture on the paper, thus leaving you with conflicting textures again. The mud used to hide tape will suck the moisture out of the texture faster than the paper on the sheetrock.
redmanblackdog is offline   Reply With Quote
Old 03-24-2011, 11:28 AM   #7
I've never hanged or taped sheetrock. I notice that some people's seams are more obvious than others. In our bathroom you can easily see the seams and screws if you look, but in the living room you can't see anything, no matter how hard you look or how you shine a light.
It might also depend on how you paint and what kind of paint you use. If the paint is good quality and you put up two coats with a roller over good quality primer it puts its own mild texture on everything.
Old 03-25-2011, 03:26 PM   #8
Drywall contractor
Rewards Points: 1,070
Smooth finish is all I would do if it were up to me. Ceiling texture is common in older homes in this area. I do repairs and texture ceilings in additions, basements, etc. to match the rest of the house. Seldom are walls textured unless it's manufactured housing. Years ago I did some work on a couple of modular homes that had textured walls and I fixed them where the 2 sections of the home were joined. Texture hides poor finishing. If you can do a proper job, there's no need for texture unless you want it. Using a proper drywall primer will prevent the joints from "flashing", but I would recommend glazing the entire surface if using any type of gloss paint...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-25-2011, 03:33 PM   #9
the Musigician
DangerMouse's Avatar
I textured the walls in our half-bath (lav and water closet, no tub) but I don't think I'd texture in the main bath.
DM
Old 03-25-2011, 05:58 PM   #10
to texture or not that is the question texture is used for various reasons and different places some people like a popcorn text some like a nock down design and others like a swirl or full texture none are eye soars if done properly and if joints are showing then the finish wasnt done right as for haveing to do it you dont and the belief that texture covers f ups is wrong too texture is done from remodels to mansions i have textured the walls and i have done plenty of slick cielings remeber the slick ceiling you better be a good mudder or have a lot of time and patience the best to do on those ceilings is what is known as a sheer coat water your mud down to the consitency of tomato soap texture mud can be a little thicker sheer coat is done after the three coats have been applied tape bed and skim role the mud on as if you are painting the ceiling then behind it take a good i prefer a 10' knife free of warps or nicks in the blade wipe off the mud you jsut put on dont get to a head of the person wipeing down after it dries sand all the ceiling be sure to check every joint and make sure all are flat before doing this process good luck the secret to drywall is patience
lrobertstoner is offline   Reply With Quote
Old 03-25-2011, 06:54 PM   #11
the Musigician
What's the secret to reading your post?
DM
Old 03-25-2011, 07:02 PM   #12
DIY staff
Rewards Points: 7,174
The 'period' key is not working?
Old 03-25-2011, 07:11 PM   #13
the secret to reading my posts is
keep your eyes closed lol sorry hate periods hated literature and such guess thats why i went into construction i dont need to know how to write a article i just need to know how to fix the problem.
! sorry i run on sentences but if you got patience to read my words then you might have the patience to do dry wall
Last edited by oh'mike; 03-25-2011 at 07:56 PM. Reason: Added spaces using the 'enter' key
Old 03-25-2011, 08:01 PM   #14
DIY staff
Adding spaces helps get respect and readers.-----You obviously know your drywall work----
It would be a shame to have your answers overlooked-----Just because folks like me--can't read a long
uninterrupted blur of words-----Just thought a word to the wise would be sufficient.
----Mike-----
Old 03-25-2011, 08:10 PM   #15
Drywall contractor
And I was expressing my personal opinion, I prefer slick. There are many who prefer or like texture. It has it's place, but back in the days of booming construction it was used to cover less than desirable finishing more often than not.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Drywall Taping - do you apply a layer of mud over the tape on your first go? newbpainter Drywall & Plaster 20 05-18-2009 06:43 AM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 10:57 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
