Where Can I Buy The "Butt Boards" - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-18-2014, 08:27 PM   #1
Rewards Points: 422
Where can I buy the "Butt Boards"
Where can I buy the "Butt Boards" for the butt joints? Home Depot? Menards?
Can they be used on ceilings?
Thanks.
Jim McC is offline   Reply With Quote
Old 01-18-2014, 08:55 PM   #2
Rewards Points: 5,974
The ones I use I get from Trim-Tex have never seen then at the box stores. Might want to try a drywall supplier. Yes they can be used on ceilings.
Old 01-18-2014, 09:30 PM   #3
Rewards Points: 422
Thanks. Is there a particular brand you recommend, or any to avoid?
Old 01-18-2014, 10:57 PM   #4
Rewards Points: 1,092
Our Spenard's have no butt boards, butt (ha ha) they have strips of cardboard that you can staple to plywood and make your own. I made butt boards for my shop out of plywood and strips of felt paper, but slicing all that felt got old. The cardboard strips are cheap and will be fast. Hope that helps.
Old 01-19-2014, 12:11 AM   #5
Rewards Points: 422
Thanks. Does anyone know of a link that shows how to install butt boards properly on a ceiling? Thanks.
Old 01-19-2014, 01:17 AM   #6
i've only used 'em once, so i am no expert. a guy here posted a pic of "real" ones, and they were about 7" wide w/ 1" wide strips near the edges. that leaves a gap between the two strips of about 5 1/2". the strips need to be about 1/8" thick, though mine were probably mostly less than that. i just hung a sheet, insert the butt board, and screwed it in, ensuring that i was not so close to the end of the 'rock that it broke out. when you install the next sheet, you'll see both 'rocks bow in a hair. that's all they need to do. mud right over the valley formed by the bowed 'rock. done. that's my take on the muthas. pretty simple, pretty slick.
Old 01-19-2014, 04:55 PM   #7
Rewards Points: 422
Thanks. I do have some of those drywall shims, and they are about 1/8" thick.
If I made some butt boards, would plywood or OSB be best? I thought the butt boards were wider than 7".
Old 01-19-2014, 06:39 PM   #8
Pretty sure wider than 7" will go measure one shortly. Yes you can make your but I don't think I would trust cardboard. I would be afraid the edge would collapse when the sheet is tightened against.
Old 01-19-2014, 06:43 PM   #9
I stand corrected the factory ones are 6" wide.
Old 01-19-2014, 07:18 PM   #10
Davejss's Avatar
Rewards Points: 740
Yet another reason why I prefer plaster vs drywall. No visible joints ever, and no special splices or butt boards needed.
Davejss is offline   Reply With Quote
Old 01-19-2014, 07:21 PM   #11
Rewards Points: 422
Thanks. Would plywood or OSB be better?
Old 01-19-2014, 07:31 PM   #12
Rewards Points: 236
make your own, very easy. DON'T use 1/8th, way to thick. you will be damaging the DW when screwing. you don't need, nor want a 1/8 deep joint. thick non corrigated cardboard is what i used, caulked down to 1/2 osb. and make the osb as wide as the cavity they are going in. and screw at least 1" away from the end of the DW. do one side completely. then do the other side, working from one end.
Fix'n it is offline   Reply With Quote
Old 01-19-2014, 07:34 PM   #13
kwikfishron's Avatar
Rewards Points: 368
You can make your own butt boards easy enough. http://www.finehomebuilding.com/how-...tt-joints.aspx
kwikfishron is online now   Reply With Quote
Old 01-19-2014, 07:37 PM   #14
Rewards Points: 236
yeah. but there is a tallant to doing it. it would take me, and most people, forever to get a good surface.
Old 01-19-2014, 08:14 PM   #15
I haven't seen anybody do plaster for at least 40+ years.
