When To Use Which Kind Of Mud - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 04:21 PM   #1
Rewards Points: 1,062
Question
when to use which kind of mud
i noticed there are 3 types of bucketed mud (purple, green, and blue) and also fast-set powder hot mud.
so far, i understand that hot mud should be used if i don't wanna wait or where there are wider gaps because of its superior strength. bucket mud, as i understand, can be used if i am not in a hurry and for regular joints.
any other distinction in application of different types of mud?
i also found these articles but they don't really specify when to use which kind:
http://www.doityourself.com/stry/the...of-drywall-mud
http://drywall101.com/articles/types_of_mud.php
thanks
Old 05-11-2012, 06:01 PM   #2
DIY staff
Rewards Points: 7,174
Here are the three common drywall muds---
Powdered 'easy sand' (not Durrabond)---used to fill gaps and voids before taping--filling in corner bead---
some use it to set paper---sometimes used for a fast setting second coat after the tape is set.
Very hard to sand---
All purpose--green lid---contains glue and is the preferred mud to set the paper--some pros use this for topcoats also---hard to sand--
Light weight--blue lid---easy to sand--used for final coat---
amakarevic (05-11-2012)
Old 05-13-2012, 11:36 PM   #3
Registered User
Rewards Points: 5,466
I use hot mud around moisture (bathrooms, basements) as it doesn't turn to mush when wet. With lightweight, I apply it thicker because it takes more material removed to get a smooth surface (grainier), compared to others.
Gary
Tags
drywall mud
What kind of cable is this? Sith717 Electrical 3 03-10-2012 01:56 PM
What kind of valve is this? mwong Plumbing 10 12-06-2011 11:33 PM
what kind of wye do I need? graysqwrl Plumbing 6 06-22-2011 04:23 PM
Painting Baseboards(does it matter what kind?) SabineTLK Interior Decorating 12 02-06-2011 07:34 AM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
