When is it dry enough ?
15 - 20 minutes, or until it begins to lose the sheen.
Don't get on it too soon, or it will flatten out way too much.
Getting on it a little late is no big deal. It will just require a lot more pressure to get the 'knockdown' look, and the texture will dry with a tendency to sluff off hundreds of tiny bits of dried edge when you rub your hand over it. This can be quickly fixed by wiping down the dried wall with a clean rag or just dragging a push broom over it.
It doesn't look as good when you let it dry too much before knocking it down, but it is still livable.
Willie T
