When Was 5/8 Drywall First Required In Garage Fire Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 10:37 AM   #1
When was 5/8 drywall first required in garage fire walls
Timc911 is offline   Reply With Quote
Old 02-23-2012, 11:25 PM   #2
Ron Paul 2012
Good Question, but I have not a clue. I know on the commercial buildings we worked with it was always doubled up 5/8 drywall sealed around with fire caulking. Actually, I am going have to complete the ceiling this week because of a recent inspection stating the ceiling wasn't sealed properly.
As the saying goes, "I woke up this morning, what government department should I thank!"
Ron Paul!
HandymanCA is offline   Reply With Quote
Old 03-02-2012, 07:24 PM   #3
Drywall contractor
Rewards Points: 1,070
Check with your local building/permit office to see when it was instituted in your area. The requirement varies by county code around here. Some don't require any. Some require ceiling and "common" wall with the residence in a "drive under" garage....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-02-2012, 08:49 PM   #4
concretemasonry's Avatar
Rewards Points: 2,640
One of the homes (built in 1973) I had had 5/8" drywall sealed and caulked if that provides some information.
Much of the current requirements are based the model codes and on the modifications of the national codes (IBC, IRC) since the local areas can always imposed tighter requirements since the research and acceptance of new facts can outpace the upgrading of national model codes and also reflect local construction methods.
Dick
concretemasonry is online now   Reply With Quote
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Help! Drywall Pulling Away from Stud on the Ceiling of our Garage Jarlanric Drywall & Plaster 8 06-23-2011 10:02 PM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
