Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-19-2009, 08:31 AM   #1
Question
Whats the longest sheet of drywall you have gotten thru egress window?
I'm ready to drywall my basement and trying picture how I am going to get the drywall down there. My egress windows are 3' feet high, by 4' feet wide, plus a few inches when you take the window out. I am just not sure how much drywall bends or is forgivable while trying to get it past the window well.
I would love to get some long drywall sheets down there if possible.
bryan
bkeech is offline   Reply With Quote
Old 04-19-2009, 09:29 AM   #2
Household Handyman
You state that you're windows are 3' high by 4 ' wide. Is the framing or the actual window opening? Measuring on a diagnol, what is the actual window opening? IF it's 48"+ then you may be able to pass a sheet of 48" sheetrock through the window by tilting it on a diagnol. IF so then you may be able to use 12 foot lengts of sheetrock.
Old 04-20-2009, 11:02 AM   #3
RippySkippy's Avatar
16' -- but that was more of a daylight basement window. How far away is the ground from the window area and is it higher than the window? You can have a huge window and if the ground if higher than the top of the window, you'll be taking in scrap sized pieces...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-21-2009, 03:49 PM   #4
Drywall contractor
14' is the longest available I'm aware of. If you can tilt it so the 48" makes it through the hole, it will bend/bow to some extent without breaking. How much depends on how "crisp" the drywall itself is...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-22-2009, 06:53 PM   #5
The ground and the top of the window are about the same level. The window well is a little taller then the ground and window.
Old 04-22-2009, 07:19 PM   #6
The window is 62' Diagonally.
Here are some picture. I was wondering about sliding them in flat at the top part of the window and window well.
Old 04-23-2009, 08:59 AM   #7
IF you can get both windows out of the frame, you're limited by the width of the opening....since the ground and surround is higher than the window.
LMASD
Old 04-23-2009, 10:31 AM   #8
You'll be lucky if you get 8' in that window, undamaged. Try the basement stairs.
Ron
Old 04-23-2009, 04:53 PM   #9
The whole window(both sides) do come out.
Old 04-23-2009, 05:02 PM   #10
What's the width of the opening with out windows?
LMASD
Old 04-23-2009, 05:06 PM   #11
Drywall contractor
If it's 4' wide with both windows out, you can likely slide the board in nearly flat. You would be limited by what's in the way in the room behind where you're sliding the rock in. It won't be easy and the more help, the better to support the board and keep it from breaking in the middle....
Old 02-05-2010, 10:24 AM   #12
I was able to get 12' in thru the window.
Old 02-05-2010, 11:32 AM   #13
But you started last April.
Ron
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 01:23 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
Egress Window Questions? cibula11 Building & Construction 12 03-15-2007 01:24 PM
