-   -   What's a good drywall to use? (http://www.diychatroom.com/f101/whats-good-drywall-use-197735/)
be-gin-ner 03-13-2014 02:15 PM
I thought I found a good drywall product with Gold Bond Gypsum Board (5/8) but after doing some research, I found reports that claimed that since this product is made in China, it had some problems (terrible odor ppl complaining of headaches and getting sick). So I wanted to know if anyone can recommend a reputable drywall? This drywall will be used in every room in our home as we are currently rebuilding. Our foundation was just done so finding the perfect drywall for our needs is next! Thank you in advance!
oh'mike 03-13-2014 03:32 PM
USG--United States Gypsum--they have a local plant--the boards are still warm if you get it on the day the truck delivers--
Sir MixAlot 03-13-2014 03:33 PM
There are a few other drywall manufacturers in the US. These two are the best. IMO. :thumbsup:
USG--> http://www.usg.com/content/usgcom/en...&-drywall.html
National Gypsum--> http://www.nationalgypsum.com/produc...px?GroupID=184
joecaption 03-13-2014 04:58 PM
The only place 5/8 should be being used is on the ceilings, the wall use 1/2".
That Chinese drywall was an issue years ago and has been addressed and is no longer an issue.
jeffnc 03-13-2014 06:25 PM
5/8" is not really needed except for fire code in garage walls adjoining internal living space. Why are you using 5/8"?
Nailbags 03-14-2014 10:10 AM
As O'mikes says USG is the best I get it delivered and it is still warm every time.
be-gin-ner 03-14-2014 02:53 PM
Thanks joecaption, I'm in Torrance, CA. I was told that 1/2 does not provide very good protection against noise (paper thin) and that 5/8 would be best. We live near a very busy intersection and could pretty much hear every car’s horn during rush hour. Also, in our media room, we were going to double up - two 5/8 sheets using green glue. I looked into QuietRock but at over $50 a sheet, didn’t seem too cost effective.
Jb1234 03-14-2014 03:22 PM
Definitely Google all that goes into sound proofing or reducing sound in a house. An extra 1/8 inch of drywall won't make that much of a difference. You need insulation and to seal every area sound can intrude. And since you live in a warmer climate I would imagine you'll have your windows open a lot of times, so that all literally goes out the window.
jeffnc 03-14-2014 07:05 PM
5/8 drywall won't make much difference - if you're looking for any real sound attenuation that's basically a waste of your time. You're going to want to look seriously into the topic, as it's a real science. Look up drywal STC and go from there. You're on the right track with QuietRock, Green Glue, etc. Setting up the wall correctly probably has as much to do with it as anything else, such as a staggered stud assembly, etc.
When sound hits a sheetrock wall, the sheetrock effectively acts like a drum head, or speaker. It literally vibrates, transmitting the sound to the other side. Do you think it makes much difference if a speaker cone or drum head were 25% thicker? No, not much. You want a better means.
Sir MixAlot 03-14-2014 07:18 PM
Here's a good breakdown of some different options for soundproofing walls: http://www.soundproofingcompany.com/...roofing-walls/ :thumbsup:
ddawg16 03-14-2014 09:45 PM
biginner.....your in my neck of the woods....
Go to Westwood building materials....Manhattan Beach/Inglewood.
http://www.westwoodbm.com/
They are open Saturday mornings....until noon
They are just slightly cheaper than HD....about the only thing HD carries now is the light weight stuff....and unless you have some high places to hang it...I prefer the real stuff.
be-gin-ner 03-17-2014 05:00 PM
Thank you, Sir MixALot, I found a ton of information on that link... some confirms what I already researched and there's new stuff which is really helpful!
Thank you, ddawg16, I def plan to request a bid from this place. It's only a few min away from me! Thanks!
Sir MixAlot 03-18-2014 12:41 PM
No problem. I'm happy to be able to help. :thumbsup:
Be sure to keep us posted as your project progresses. :thumbup:
