What's The Best Way To Patch Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 11:43 AM   #1
Newly Retired
tuchodi's Avatar
What's the best way to patch drywall
I have done some reno's and now have to replace some drywall that I had removed while doing the reno's. Some patch's are round holes in the ceiling where I moved a light and some are on the wall where I took out a stub wall. My question is what would the experts do to prepair the edges of both the existing drywall and also the patches and how close to the original size do I make the patches(what should the gap be between the patch and the original) to make the mudding the easiest. Also when you cut out drywall there are quite often frayed edges so how would you prepair them before mudding(cut the 2 edges at a 45)?
Thanks in advance
PS: the replacing drywall is the same thickness as the original.
tuchodi is offline   Reply With Quote
Old 06-18-2010, 11:53 AM   #2
Handyman
Rewards Points: 512
If the paper is frayed, then yes, trim it otherwise should be fine.
Here's a video you might be interested in for small repairs. For the circle cuts you can either cut new circles or square them off. Gap or no gap is fine.
canadaclub is offline   Reply With Quote
Old 06-18-2010, 10:07 PM   #3
Newly Retired
tuchodi's Avatar
Thanks for the link canadaclub. Every little tip is appreciated. Also if the paper is frayed would you trim both the hole and the patch or just the hole?
sanding into paper on drywall patch joseph2293 Drywall & Plaster 11 02-23-2010 09:53 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 06:25 AM
