Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-09-2009, 12:23 PM   #1
What's the best way to clean up drywall dust?
I hung and have begun finishing four sheets of drywall in my family room. I have a little Stinger shop vac. I don't want to blow the motor in it nor do I want to spray drywall dust out the blower of the vac, so I'm curious as to what you guys would recommend I use to clean up the drywall dust.
ScottieBaseball is offline   Reply With Quote
Old 02-09-2009, 01:19 PM   #2
Home Depot sells this device for about $35.00-$40.00 that you fill with water and use your vacuum to suck up the dust with. The dust goes into the water, not the vacuum. It's generally used to sand the drywall as it sucks up most of the dust at that point. but you shuold be able to adapt it temporaraly for such a small job.
Ron
It's called, "Sand & Kleen"
Old 02-09-2009, 03:25 PM   #3
Remodeling Contractor
By a cloth filter. Sears sells a good one that will fit on your stinger
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 07:05 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Removing drywall dust after sanding? ponchoman1 Painting 6 10-13-2006 08:33 PM
Drywall dust in floorboard crevices ponchoman1 Flooring 1 04-30-2006 03:19 PM
