Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-07-2013, 12:57 PM   #1
what are you techniques for trimming drywall
lets say, you cut a piece of drywall but you need to adjust one side just a tiny bit (for sake of arguement lets say 1/4" or less)
what ways do you "trim" it down?
do you use a drywall planer or do you use a utility knife and just shave it down and keep fitting it up as you go
or do you do something else?
echobravo is offline   Reply With Quote
Old 01-07-2013, 02:01 PM   #2
SURFORM hand plane
ToolSeeker is online now   Reply With Quote
Old 01-07-2013, 02:06 PM   #3
Trucon01's Avatar
Would this work for you??
http://www.homedepot.com/h_d1/N-5yc1...1#.UOscwWfEy9I
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-07-2013, 02:53 PM   #4
gravity always wins
10-4 on the Surform hand plane.
Old 01-07-2013, 07:20 PM   #5
yup you can use a rasp or i take my knife and cut a V then cut down the V to what i need if you get what i mean.
princelake is offline   Reply With Quote
Old 01-07-2013, 08:24 PM   #6
automated tool pro
rasp it!
drywallfinisher is offline   Reply With Quote
Old 01-07-2013, 08:40 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
try to not cut it so tight. a small crack is better than forcing it in
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-07-2013, 09:06 PM   #8
Super Moderator
I usually take the knife and slice a bevel cut from the back--then another from the front and a third to remove the peak of gypsum---then a quick cleanup with the rasp---
to much removal with the rasp and you end up with a bunch of paper shreds that need cleaning up with the knife---
Old 01-07-2013, 10:17 PM   #9
Originally Posted by Trucon01 View Post
this is what i use, and it works very well, except for below. i just try to not need it.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 01-07-2013, 10:25 PM   #10
oh'mike thats exactly what i do. i dont always my rasp with me. i normally dry fit a piece with my knife still in my hand/ handy so its quicker that way
The Following User Says Thank You to princelake For This Useful Post:
oh'mike (01-08-2013)
Old 01-08-2013, 06:39 AM   #11
Super Moderator
Sometimes, I'll screw in the sheet with the mismatched cut overlapping the next sheet---then run my roto-zip along the seam to remove the excess.
mae-ling (01-09-2013)
Old 01-08-2013, 04:47 PM   #12
Originally Posted by ToolSeeker View Post
SURFORM hand plane
thats what i used. i just wanted to make sure i wasnt overkilling it
thanks for the feedback
The Following User Says Thank You to echobravo For This Useful Post:
ToolSeeker (01-08-2013)
Old 01-09-2013, 04:04 AM   #13
It takes a different technique to cut out a section of only 1/4" - I think it's explained in Myron Ferguson's book. If not there, maybe finehomebuilding.com. Bottom line, a quarter inch is a lot to be rasping so I'd prefer to cut.
jeffnc is online now   Reply With Quote
Old 01-11-2013, 07:46 PM   #14
Any one know the best wall scanner for mesh wire plaster?
trungkieubinty is offline   Reply With Quote
Old 01-11-2013, 08:43 PM   #15
Super Moderator
If you are looking for a stud finder that can read through plaster and mesh? You are not going to find one--sorry---look for nails in the base moldings or drill holes and hope to hit a stud----
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
