What To Use To Cover The Window Framing When Drywall Wont Fit? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 01:22 AM   #16
Man, you might think you donít need any wood trim but tbh, you do! Also, you can skip the curtains for those, get window frosting instead
patrickbuzacott is offline   Reply With Quote
Old 06-17-2013, 11:59 AM   #17
Window frosting?? In the living room?
You want everybody to get window frosting regardless of which room they are talking about. It may be interesting to see your own place.
creeper is offline   Reply With Quote
Old 06-17-2013, 02:13 PM   #18
Rewards Points: 578
Window frosting? Windows are there for a reason!
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 06-17-2013, 02:27 PM   #19
Roofmaster
Rewards Points: 2,210
Use white aluminum shingle drip edge, and set it with hot melt glue.
Old 06-17-2013, 02:42 PM   #20
Roofmaster
Are those windows single pane? Aren't they going to to load up with condensation and frost up in the winter? Oops, is that what the frost comment was about? Well, anyway if you are where it gets cold, and those are single pane, they are really gonna frost up in the winter time under propane heat. Lotta water in Propane.
Old 06-18-2013, 08:22 AM   #21
Rewards Points: 578
i dont use propane heat, propane scares me and i prefer electric. Yes they are single pane but i have not seen any condensation yet, and we just went through one of the coldest winters in several years
Old 06-18-2013, 05:22 PM   #22
Roofmaster
OK Maybe the drip edge will work then. Maybe you can slide it behind the edge of the window, nail and tape the flange, and caulk in the angle change with white silicon bathroom sealant? Just a thought.
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 01:48 PM
Deck - Framing around a bay window - house rim joist changes levels? jkwaldron Building & Construction 3 10-17-2011 08:24 PM
L framing for window shutters robismyname General DIY Discussions 3 02-03-2011 04:17 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
