What Type Of Wall/how Best To Repair? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 04:36 PM   #1
416
What type of wall/how best to repair?
Hi. I'm taking care of a few things around the house and I was wondering what kind of wall this is and how best to repair it.
There are vertical seems that run the height of the walls. Most of the house is plaster, but this seems to be a bit different in that it almost seems like a covering....
Help is much appreciated.
416 is offline   Reply With Quote
Old 02-26-2013, 05:49 PM   #2
MarginallyQualified
Rewards Points: 2,464
Except for the very precise line...
the wall appears to be skim coat plaster over (old school) wall board.
With a very poorly adhering paint job over that
The Following User Says Thank You to TarheelTerp For This Useful Post:
416 (02-26-2013)
Old 02-26-2013, 09:30 PM   #3
416
Thanks. The vertical line is part of what's throwing me.
It feels like there's a bit of a hollow spot behind the area...obviously this is the reason for the damage.
Any ideas on how to fix? Or do I just drywall over the whole thing?
Old 02-26-2013, 09:53 PM   #4
Rewards Points: 5,974
You could V out the seam tape and mud as you would any drywall butt joint, But not being sure what it is or what's behind it that's kinda iffy. You could remove it and drywall the intire wall. The worst solution I can think of is drywalling over it.
Old 02-27-2013, 08:16 PM   #5
416
Hmmm. I noticed in one other upstairs room that there seem to be these seams running vertically on the walls.
I have another tread about a ceiling too that also appears to have a similar 'papering'. I can't sort out what this paper is or why it was used.
It sure seems to make things a lot more of a pain to repair.
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Repair exterior stucco on house.... stupid48 Concrete, Stone & Masonry 7 07-21-2012 04:40 PM
ACE Hardware- thin type L copper pipes? MikeDobbs Plumbing 8 05-28-2012 07:34 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
