What type of texture and how to blend?
I just bought my first home about a month ago and have started making some repairs, more like updates to the house since it's about 15 years old and wasn't that well taken care of. not terrible, but needs things replaced. One of my first projects is remodeling one of the bathrooms. I am starting with replacing the heat lamp and fan. They were separate units and I bought a unit that is all in one. However, I had to take out and replace about a 4'x2' area of drywall. I am still working on the mudding/taping/sanding but am wondering what type of text I have and the best technique to add to the new sheet and to blend it in. Here is a picture of the wall on what the texture looks like. I believe this is skip trowel, am I correct?
http://s117.photobucket.com/albums/o...t=CIMG0007.jpg And what is the best way to add this to a new sheet of drywall and blending it in? |
Looks like knockdown. Just Google "putting up knockdown texture". Why not add another layer of drywall over the entire ceiling and do a smooth finish?? (I'm not a big fan of texture.)
I don't like any texture at all but I'm not planning on living here forever and to smooth out one ceiling I would end up doing the entire house. That was my original plan but that is going to be a lot of work on smoothing and making things perfect. Or a lot of money on paying someone to make it perfect for me. |
Understand. Just a suggestion. I've done a lot of similar repairs where the homeowner just did one room and slicked the ceiling. I tend to agree with your thinking though. My house had stipple when I bought it. I stippled my basement ceilings to match when I did a couple of rooms even though I don't like it.....
I would say if it turns out that I stick with this house longer than a couple of years, I may smooth out all the walls and ceilings. Actually I plan on adding 500 feet or so to the back of the house if I stay longer then 2 years. But this is my first home and pretty much am just using it as an investment, maybe a future rental which I do currnetly rent out a couple of rooms right now. The renters pay for my mortgage.:thumbup:Which I just really take that money and put it into the house.
But it looks like I do have knocked down. Looks pretty simple to do, just will need to practice a few times before I spray the ceiling. |
Absolutely. Try your hand on some scrap drywall first. Even if it's not EXACTLY the same, it shouldn't be noticeable once the whole ceiling is painted. Of course you'll know, but most people don't go into a room and look up at the ceiling. (Except those of us who do this type of work...)
i agree this is a nock down that was sprayed on get you a sprayer and a sheet of rock and experiment
you can spay the whole cieling again and put your own print on the likely hood of you matching this pattern exactly is not good those who have done this work knows that every person does it diff we can try to match and for the most part the every day joe can't see the diff until later to smooth this cieling would be rather easy take a 8" 3/4 napp roller make sure you use a good thick frame roller thin mud down to the consistency of tomatoe soup your going to use two diff roles first role the width depending on size and temperture drying time what not role all out then wipe tight then cross role it against your role you first done with 12" knife start wipeing tight last sand and touch up if you want it smooth this is a perfect way to slick down this ceiling at low cost to your budget ps if you dont know ask a pro |
if you plan on doing it yourself, buy bag mud specifically made for texture, from USG for example or Tuf Tex. it will do better then box or bucket mud. you have knockdown. the picture looks familiar for some reason.
| All times are GMT -4. The time now is 03:43 PM. |
