What Type Of Drywall For Garage - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 10:37 AM   #1
Rewards Points: 640
What type of drywall for garage
I need to redo a wall in my garage that is drywalled right now, but I have to rip it out for some remodeling that is going on and to insulate the wall the one side is inside the house and a heated side the part in the garage is cold and unheated, but for some reason they didnt insulate this wall and the room inside is very cold in the winter inside the warm zone... but anyways... what is the best type of drywall to use? the garge gets very hot in the winter (100 degrees usually) and very cold in the winter (freezing and below almost constantly)... normal drywall? or water resistant stuff / mold resistant due to the massive humidity changes the garage goes through? also what thickness is good for this part since it is a wall that goes into the actual living space?
the walls are 2x6 stud walls that I am going to insulate with R-19 at the minimum (R22 if I can find it) right now it has 1/2" drywall on both sides... but should it be thicker to help block out some garage noise? or better fire barrier? what are your suggestions before I buy the wrong stuff... thanks!
BlueBSH is offline   Reply With Quote
Old 04-01-2010, 08:49 PM   #2
jlhaslip's Avatar
Rewards Points: 2,162
Code here would be 5/8 " Fireguard for the garage side of that wall.
Stagger the joints by a minimum of 8" for a second layer to get a better fire rating.
Taped plus 2 coats of mud to allow for a proper fire rating.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-02-2010, 04:56 PM   #3
Drywall contractor
Rewards Points: 1,070
Usually in a residential setting, one layer of 5/8" is normally used on the common wall(s) and ceiling of the garage. As stated above, two layers would give a better fire rating and would help with noise transmission to some extent. Check local code to see if this is applicable in your situation. If it's the wall where your entry door is, you'll have to extend the jamb on the door to compensate if you use an extra layer.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-02-2010, 05:12 PM   #4
Question
You (probably) meant "Joists"! (Intending to say) "Stagger the Joists... By a minimum of 8" (instead of the standard 16"!)
spark plug is offline   Reply With Quote
Old 04-02-2010, 05:15 PM   #5
Arrow
I doubt if 2 layers of 5/8" sheetrock is safe to install on a ceiling without special reinforcements (i.e. framing?)!
Old 04-02-2010, 06:28 PM   #6
Drywall contractor
I'm sure he meant joints. When double layering drywall for firecode, the joints must be staggered between layers.
I doubt the weight of 2 layers of 5/8" firecode would be an issue on the ceiling, but certainly worth checking into (again) with local code officials. It's pretty much overkill, but something the OP queried about. In many locales, 1/2" is perfectly acceptable.
The Following User Says Thank You to bjbatlanta For This Useful Post:
jlhaslip (04-02-2010)
Old 04-02-2010, 06:57 PM   #7
poster said wall
The older I get the better I was
Old 04-02-2010, 08:51 PM   #8
jlhaslip's Avatar
I meant 'joints' of the second layer of drywall when compared to the 'joints' of the first layer.
The 'seams' of each layer needs to be staggered a minimum of 8" or the rating doesn't apply.
Old 04-03-2010, 09:13 PM   #9
Thumbs up
As far as I know, in NYC "Fireproofing" where required, calls for using 5/8" drywall. But fastening to ceilings, I'm certain requires more than the basic methods used with 1/2"!
Last edited by spark plug; 04-03-2010 at 09:14 PM. Reason: Using the same terms sequentially
Old 04-03-2010, 11:11 PM   #10
blueBSH, Massive changes in humidity? I'm not sure what you mean. As mentioned in previous posts you should use Type "X" 5/8" board between the garage and the heated living space (on the garage side of the walls.) Normally, code also requires Type "X" 5/8" board on the ceiling also. The remainder of the garage can be finished with 1/2" board. Always fire tape your joints. Don't worry about using a mold and moisture resistant board, not worth the money. If the outer garage walls and ceiling are not insulated then spend your money there and insulate them. You could also run some heat out to the garage if that is practical for you. Unless you have a dirt floor you should not have humidity problems if you follow my suggestions. Drywall board does not like unheated spaces. Over time it could deteriorate on you. At a minimum I would apply a coat of primer/sealer to further protect your board.
Cheers, and remember, my advice is worth what it cost.
Ron Franck is offline   Reply With Quote
Old 04-04-2010, 07:38 AM   #11
Drywall contractor
I don't know where you're located in IL, but I'm from Belleville originally and it gets awfully humid there (near St. Louis and the Mississippi). Same here in the Atlanta area. Most people tend to leave their garage doors open a lot of the time, so humidity DOES enter into the equation. I wouldn't worry with MR or Mold Resistant either.....
Old 04-04-2010, 08:52 AM   #12
The kind of humidity I was thinking about was more along the lines of frost in the garage on the inside of the exterior walls during freezing weather. Properly insulated and a good vapor barrier should prevent any structural problems. I don't see Summer humidity changes being problematic if his attic is properly ventilated.
Another option in the garage would be to use 1/2" OSB finished with a glossy oil based paint wherever Type "X" is not required. It's tough as nails and takes a lot of abuse in garages without showing any wear.
Old 04-04-2010, 09:54 AM   #13
Drywall contractor
Gotcha. I've got an open carport that had drywall and stippled ceiling. When the stipple started turning loose a couple of years after we bought it (as expected) the drywall came down and plywood went up. Walls are same siding as the house, of course.
Old 04-05-2010, 11:54 PM   #14
Rewards Points: 256
ive seen triple layer 5/8ths on some multi family tuck under garages those were on very heavy laminate beams .. you really dont need more than 1 layer unless your in a multi family . last ive known anyways ....
oldrivers is offline   Reply With Quote
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 02:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 06:21 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
