What Type Of Corner Bead To Use - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 12:00 PM   #1
Rewards Points: 1,010
What type of corner bead to use
Finished mounting the drywall and now it's time to work on the corners. I will be working where the ceiling meets the wall, wall corners, and also around doorways for a closet. There are a lot of different types of corner bead products...metal, plastic, paper, paper over metal, etc.
I was curious of what type you all prefer and why.
spaceman spif is offline   Reply With Quote
Old 02-11-2013, 01:15 PM   #2
Registered User
Rewards Points: 526
Fasteners into framing may show later when the framing moves- structurally or with seasonal changes; http://www.usg.com/rc/brochures/shee...e-en-J1996.pdf
Page 6; http://bestdrywall.com/files/ReduceCallbacks.pdf
Gary
Old 02-11-2013, 06:34 PM   #3
Rewards Points: 512
inside corners and flat/butts paper tape. the best product for outside corners is no coat ultra flex 325 http://www.no-coat.com/.docs/pg/10291
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
ToolSeeker (02-12-2013)
Old 02-12-2013, 07:40 AM   #4
Rewards Points: 6,034
^ couldn't have said it better.
Old 02-12-2013, 10:23 AM   #5
Thanks all!
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Corner bead on a recessed ceiling jackrobat Drywall & Plaster 5 03-25-2011 09:42 AM
Bullnose Corner bead question ryan5068 Drywall & Plaster 11 03-13-2011 07:43 PM
corner bead crack igneous Drywall & Plaster 4 02-08-2011 01:11 PM
