What Type Of Caulking Do I Need For Shower ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 11:14 AM   #1
What type of caulking do I need for shower ?
Hi ... Just did the drywall's on a shower unit and I need to know what exact type of caulking do I use for the corners ? Or should I use something else ? Thanks
Diydude905 is offline   Reply With Quote
Old 09-26-2012, 01:39 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Typically silicone caulk is used in showers and baths. I'm trusting that you are using more than just plain drywall. Tub and tile caulks are silicone, but also incorporate some mold inhibitors in thier formulas.
Old 09-26-2012, 03:31 PM   #3
Thanks for the tip that exactly what I did get at home depot mold free waterproof Silicone . And yes I'm using the waterproof drywall type . Thanks
Old 09-26-2012, 05:55 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
It is not mold free, it might be mold resistant but it will degrade in a years time and need replaced. At least that has been my experience.
Old 09-26-2012, 06:00 PM   #5
Rewards Points: 13,296
The area between the sheetrock and an enclosure is never done with 100% silicone.
It's not paintable.
Siliconeized that says paintable right on the lable will work.
Old 09-26-2012, 06:14 PM   #6
you need more then drywall behind the tile. some type of waterproofing needs to be behind the tile. if you use drywall you can go over it with kerdi. if you use cement board you can use a paint on waterproofing like red guard or similar. just drywall behind tile is doomed before you use it the first time. grout is not water proof so you will end up with moisture behind the tile. when you say waterproof drywall are you referring to green board? drywall hasn't been allowed in showers for years unless its covered with kerdi. use color matched caulk that matches your grout in the corners or 100% silicone on the inside. but if you don't waterproof behind the tile it doesn't matter what you use. what did you use to seal the joints in the waterproof drywall with?
Old 09-26-2012, 08:40 PM   #7
Rewards Points: 512
here ya go http://www.dap.com/product_details.a...=21&SubcatID=5
princelake is offline   Reply With Quote
Old 09-26-2012, 09:24 PM   #8
Rewards Points: 5,974
I think i'm missing something here, he never said anything about tile. I hope he is not doing just drywall. and I have never heard of waterproof drywall. I wonder if this could be one of those fiberglass 3 piece units.
The Following User Says Thank You to ToolSeeker For This Useful Post:
oh'mike (09-27-2012)
Old 09-27-2012, 03:41 PM   #9
@DannyT ... Yes to the green board type . I had a guy do my bathtub tiles years ago . Now I am changing the bathtub and to get the bathtub out I had to break the bottom tiles . So now I'm redoing those tiles .
Old 09-27-2012, 04:49 PM   #10
then silicone between the tile and tub
Old 09-27-2012, 05:29 PM   #11
Yep , that is what I am going to do . Now that I know which type of silicone to use ... Thanks all
exterior caulking for bathroom? hohadcr Kitchen & Bath Remodeling 5 06-28-2012 01:25 PM
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 11:49 PM
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 01:30 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
