-   -   What type of caulking do I need for shower ? (http://www.diychatroom.com/f101/what-type-caulking-do-i-need-shower-158051/)
Diydude905 09-26-2012 10:14 AM
Hi ... Just did the drywall's on a shower unit and I need to know what exact type of caulking do I use for the corners ? Or should I use something else ? Thanks
Maintenance 6 09-26-2012 12:39 PM
Typically silicone caulk is used in showers and baths. I'm trusting that you are using more than just plain drywall. Tub and tile caulks are silicone, but also incorporate some mold inhibitors in thier formulas.
Diydude905 09-26-2012 02:31 PM
Thanks for the tip that exactly what I did get at home depot mold free waterproof Silicone . And yes I'm using the waterproof drywall type . Thanks
chrisn 09-26-2012 04:55 PM
It is not mold free, it might be mold resistant but it will degrade in a years time and need replaced. At least that has been my experience.
joecaption 09-26-2012 05:00 PM
The area between the sheetrock and an enclosure is never done with 100% silicone.
It's not paintable.
Siliconeized that says paintable right on the lable will work.
DannyT 09-26-2012 05:14 PM
you need more then drywall behind the tile. some type of waterproofing needs to be behind the tile. if you use drywall you can go over it with kerdi. if you use cement board you can use a paint on waterproofing like red guard or similar. just drywall behind tile is doomed before you use it the first time. grout is not water proof so you will end up with moisture behind the tile. when you say waterproof drywall are you referring to green board? drywall hasn't been allowed in showers for years unless its covered with kerdi. use color matched caulk that matches your grout in the corners or 100% silicone on the inside. but if you don't waterproof behind the tile it doesn't matter what you use. what did you use to seal the joints in the waterproof drywall with?
princelake 09-26-2012 07:40 PM
here ya go http://www.dap.com/product_details.a...=21&SubcatID=5
ToolSeeker 09-26-2012 08:24 PM
I think i'm missing something here, he never said anything about tile. I hope he is not doing just drywall. and I have never heard of waterproof drywall. I wonder if this could be one of those fiberglass 3 piece units.
Diydude905 09-27-2012 02:41 PM
@DannyT ... Yes to the green board type . I had a guy do my bathtub tiles years ago . Now I am changing the bathtub and to get the bathtub out I had to break the bottom tiles . So now I'm redoing those tiles .
DannyT 09-27-2012 03:49 PM
then silicone between the tile and tub
Diydude905 09-27-2012 04:29 PM
Yep , that is what I am going to do . Now that I know which type of silicone to use ... Thanks all :thumbsup:
