#1 |
What type of brush for this texture?
We did repairs in our kitchen and had to patch a piece of drywall on our ceiling. The ceiling is a Rosebud texture. Need help finding out the exact brush that created this look. I've attached a pic of the ceiling. Any help would be appreciated. Thanks, Linda
#2 |
Disabled wood vet
Try dabbing the wet mud with a large sponge. That looks like it will be hard to match.
Sent from a Samsung Galaxy S2 |
#3 |
Tileguy
My guess is a large "natural sponge" was used to make that pattern.
#4 |
From what I have found online it is done with a brush stomp, but no where did I find exactly what brush was used.
#5 |
Tileguy
That's not a brush stomp. The veining is much smaller using a brush and a brush won't deliver those suck marks.
#6 | |
What type of brush for this texture?Quote:
#7 |
http://www.youtube.com/watch?v=0Fa6n...layer_embedded
If the plan is to match exactly what's up there now and have it blend in, not going to happen in most cases. More often the whole ceiling would have to be redone. |
#8 | |
Tileguy
You want a name to call your brush? Try "crows-foot". |
#9 | |
#10 | ||
Tileguy
![]() Quote:
#11 |
retired union carpenter
this pattern looks like a leaf pattern to me, like like on a tree? I've seen texture rollers suppoed to leave this pattern or similar. when rolled over wet mud. you might look into texture rollers. probably have to enlarge area to blend in. you might find something suitable without redoing entire ceiling?
as always, just my thoughts good luck coupe/Larry http://www.all-wall.com/Categories/D...xture-Rollers/ some people come here looking for advice to help them with a project. others come here trying to help those seeking help. some just come for something to do, contradicting others ideas of helping, this is the closest I've found....http://drywall101.com/articles/textu...ps/rosebud.php as always, just my thoughts, good luck Last edited by coupe; 12-14-2011 at 05:55 PM. |
#12 | |
Disabled wood vet
#13 | |
#14 |
Tileguy
Why do you people come to a DIY forum for advice and then when you receive advice from seasoned veterans of the trades insist on arguing about the information you are getting?
You are wanting to define something that can't be defined. No two applications are exactly the same. Texturing ceilings can be done in any number of methods using uncountable techniques and tools. To find a website that says something about the knowledge of the single individual that created the website and then expecting everyone else to agree is baseless and senseless. Especially in this case. Any number of methods will recreate the pattern you now have, (but not exactly) you will never pin this down to a single tool or a single product. The thing to do is to buy the tool you think you want to use, mix up some compound, and make up a sample. See if it suits you, then proceed from there. Just because Bill sees a rosebud doesn't mean John sees a rosebud. I certainly don't. |
#15 | |
A Little Of Everything
![]() If I were you I'd take several sponges, or rags, or whatever, and practice on some of your left-over drywall. If you get something that's really close, try it on the ceiling. The only time I matched a ceiling texture (after replacing drywall) was a swirl texture, applied with a broom or brush. It was a HUGE pain in the butt, and took me about 3 tries, but I finally got it close enough that nobody can tell the new from old. And what I did was a whole lot easier than what you're trying. ![]() It's almost a gaurantee that you will not get the pattern to match perfectly, so you'll have to decide just how good is good enough. Good luck! |
| Display Modes | |
| Best way to cut in and not leave brush marks? | twilightcall | Painting | 14 | 02-17-2012 04:19 AM |
| Can you texture plaster walls? | destes50 | Painting | 5 | 11-06-2009 10:51 AM |
| primer not adhering to drywall texture? | eli_carson | Drywall & Plaster | 10 | 08-18-2009 02:46 PM |
| Brush marks when painting roof HELP | Toymit | Painting | 5 | 03-09-2009 03:48 AM |
| Cutting - in | Illinois G.C. | Painting | 11 | 11-24-2008 03:04 PM |
