What Are These Spots On The Back Of Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 09:09 PM   #1
What are these spots on the back of drywall?
Buying this house, the biggest issue is the quality of the basement finished wall construction. Inspector never saw this on the back of drywall.
tcostigl is offline   Reply With Quote
Old 02-25-2012, 09:16 PM   #2
Rewards Points: 13,456
Looks like moisture stains.
Old 02-25-2012, 09:26 PM   #3
Thanks. It's most likely moisture related. What we're wondering is if it looks like mold? Poor quality sheetrock(Chinese)? And if not mold how would water spots get there?
Old 02-25-2012, 10:21 PM   #4
It's in a basment, the most moist area in any house.
Old 02-25-2012, 11:09 PM   #5
long island, NY
if you haven't signed on the dotted line yet for this home, get that wall tested for mold! It could be much more extensive than that and could even be affecting home air quality....
diy'er on LI is offline   Reply With Quote
Old 02-25-2012, 11:18 PM   #6
that is mold!
Hardway is offline   Reply With Quote
Old 02-26-2012, 09:19 AM   #7
Rewards Points: 512
looks like water stains to me and not mold. could be a million ways as to how it got there. since you can see the studs and the back of the drywall its an unfinished room. could be from something spilled, laundry tub splash, whatever, even when the guys were delivering the drywall to the house it could have started to rain a bit. although your house is usually the largest invest in your life and dont want a lemon it wouldnt hurt to investigate before purchasing. i wouldnt get to worked up about it unless the other side of that wall is a bathroom
princelake is offline   Reply With Quote
Old 02-26-2012, 12:53 PM   #8
Registered User
Rewards Points: 5,492
Moisture staining (as Joe said) condensing there after coming through the bottom plate, pressure treated or not without a sill sealer: http://www.greenbuildingadvisor.com/...-building-code
Gary
The CELLAR gbwillner Project Showcase 112 02-17-2012 10:00 PM
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
