What Are These Hairs In Old Plaster? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 03:59 PM   #1
Rewards Points: 1,062
what are these hairs in old plaster?
This plaster is 100 y.o., what are these hairs? I need to do some patching, what should I use?
Old 07-14-2012, 04:01 PM   #2
Rewards Points: 13,712
Horse hair.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
amakarevic (07-14-2012), mae-ling (07-14-2012), Ravenworks (07-15-2012)
Old 07-14-2012, 04:04 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
while usually called ''horse hair'' in this country it was usually from cattle and hogs
Tom Struble is offline   Reply With Quote
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
Old 07-14-2012, 04:21 PM   #4
liscenced electrician
Rewards Points: 538
its added for strength. Same concept as rocks in concrete, mesh wire or rebar in concrete, fiberglass fibers in....... fiberglass (as opposed to just straight resin)
jimmy21 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimmy21 For This Useful Post:
Old 07-14-2012, 04:37 PM   #5
what should i patch it with?
Old 07-14-2012, 06:11 PM   #6
hair of the dog
Old 07-14-2012, 08:16 PM   #7
Too Short? Cut it Again!
Lath looks intact so you should be alright with patching plaster. If it is a large area you could staple some wire mesh to the lath for reinforcement.
Old 07-15-2012, 04:17 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
go to the local farm and shear a pig or a cow or a horse
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 08:28 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
