What Is This Stuff? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 08:20 PM   #16
Rewards Points: 6,652
Probably not. This is the list from mesothelioma.com of the products that contained asbestos http://www.mesothelioma.com/asbestos...ure/companies/ I know that the Gypsum board used in my home did not, because it was made by USG (U.S. Gypsum). How did I find that out, it was stamped all over the backside of the board, and we could see it from the basement without tearing down a wall, where the product stamp was available to find that info.
Old 09-13-2012, 08:30 PM   #17
langless28's Avatar
Rewards Points: 152
Appreciate the thorough responses, I'll take some precaution and see if I can find a chunk with some markings. My father (retired contractor/architect) insists there is no asbestos either.
langless28 is offline   Reply With Quote
Old 09-13-2012, 08:45 PM   #18
If you go to mestheloma.com and do a search for the company name, it should return back a result.
Old 09-13-2012, 09:58 PM   #19
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If there is asbestos it won't be in the gypsum board, it will be in the masonry product that covers the gypsum board.
XXX
Old 09-13-2012, 10:34 PM   #20
Check the link I posted bud. National Gypsum was one of the companies that used a Gypsum board type product, that contained Asbestos.
"Many of these products were marketed under the "Gold Bond" brand name. Potentially dangerous National Gypsum products that contained asbestos included wallboard"
Old 09-15-2012, 02:03 PM   #21
langless28's Avatar
Rewards Points: 152
No manf. Stamps on my board, just "06256BK" it is also in 16" wide sheets. Numbers could be a date code? 56' and the house was built in 59'?
Edit:
Upon some google search for "bk" gypsum, there is a company called b.k. Plaster and gypsum corp over in Thailand. This company does not show up on that website. This all could be a guess though.
Edit 2: they may have been established in 1999 so maybe a dead end.
Old 09-27-2012, 12:22 PM   #22
langless28's Avatar
Rewards Points: 152
So in case anyone cares or as reference for future diy'ers. that type of wall cover has zero asbestos in the sample that i sent to the lab. granted every type and every place is difference but in my case, MY rock-lath, plaster, and skim coat contained no asbestos fibers.
fuzzy stuff growing on basement floor peggy whiting Flooring 6 11-06-2010 12:46 PM
Am I using the right stuff? davecuz Flooring 2 10-18-2010 11:35 PM
Great Stuff and 6 mil poly vapour barrier maljeff Building & Construction 4 09-30-2010 01:26 PM
Some newer stuff joeyboy Project Showcase 11 01-22-2008 12:14 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 12:21 PM
