Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-09-2012, 04:28 PM   #1
What is this stuff?
Repairing a hole in the wall in my old rental, I start opening a square hole to see this weird two-layer wall material. The outer layer seems to be some sort of brittle cement. Cutting a ten inch line in it took the teeth clean off my jigsaw blade.
What is it, and do I need any special prep to patch it with a piece of normal drywall?
Thanks!
IdahoEv is offline   Reply With Quote
Old 09-09-2012, 05:00 PM   #2
Tileguy
Bud Cline's Avatar
What is this stuff?
It's a form of plaster.
The tiny fibers are asbestos.
You can do what you want.
Old 09-09-2012, 06:47 PM   #3
What is this stuff?
I didn't see anything fibrous, just something cement like. Is that stuff definitely asbestos? Do I need to call an asbestos pro?
Old 09-09-2012, 11:16 PM   #4
Tileguy
Bud Cline's Avatar
What is this stuff?
Years ago when plaster was applied over wooden lath strips, horse hair was used to bind the mix and help to unitize the cement product. Go figure!
Then later the lath sort of went away and after WWII they started using mostly drywall backer board like you have. Around that time the horse hairs were replaced with asbestos fibers. The fibers were basically the size of horse hairs and slightly smaller. I'm thinking the vintage I see in your photo would have contained asbestos but maybe not.
Too late now to worry about it. In most all cases any threats from asbestos would be directed at workers using the mineral and working with it over a long period of time. Some people these days freak needlessly at the mention of asbestos and they over-react. Some asbestos abatement companies like to use fear tactics to persuade consumers to use their services. I'm not saying there isn't a threat I am just saying that the danger is in the eyes and fears of the handler. Years ago when I was certified as an asbestos abatement contractor I learned a lot about the product and quite frankly I wouldn't be at all concerned doing your project. This is a judgement-call and you have to make the call.
The Following User Says Thank You to Bud Cline For This Useful Post:
ToolSeeker (09-19-2012)
Old 09-09-2012, 11:51 PM   #5
What is this stuff?
Okay, good to know. How do I go about cutting it? The stuff destroyed my jigsaw blade in moments, and I still have three sides of the hole to square up. I also need to cut above and below a horizontal stud ... normally I'd do those cuts with a utility knife but somehow i doubt that would do it here. Maybe a chisel for those spots.
At least discovering this stuff explains one thing. Pulling out a picture-hanging nail in this house always results in a half inch wide crater, no matter how careful I am. I though it was just crappy ancient drywall.
Old 09-09-2012, 11:58 PM   #6
Tileguy
Bud Cline's Avatar
What is this stuff?
There are blades made with a carborundum (grit) edge, those are your best bet but you may still gobble-up more than one blade.
I use a 4" angle grinder with a diamond blade but dust is a huge issue when doing it that way.
You could also use an angle grinder with an abrasive (masonry) blade.
I would not do too much pounding with a chisel if it isn't totally necessary. Just my thinking.
Old 09-10-2012, 05:53 AM   #7
paper hanger and painter
chrisn's Avatar
What is this stuff?
For sure , wear a mask
Old 09-10-2012, 08:10 AM   #8
bbo
What is this stuff?
and feel free to mist with water to keep the dust down.
bbo is offline   Reply With Quote
Old 09-10-2012, 08:21 AM   #9
Average Joe/ex-Navy IC3
gregzoll's Avatar
What is this stuff?
Rock-Lathe/Gyp-Rock.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-10-2012, 08:28 AM   #10
What is this stuff?
I use a Roto Zip with a vacuum attachment and use a tile bit.
I have also cut it with what amounts to a small ciruler saw with a vacuum attahment with a diamond blade that also has a vacuum attachment so you can hook up your shop vac.
Old 09-13-2012, 06:46 PM   #11
langless28's Avatar
What is this stuff?
I think I have this stuff too. What is the technical name for it? Would gutting a hole kitchen be a bad idea if this was the walls?
langless28 is offline   Reply With Quote
Old 09-13-2012, 07:09 PM   #12
gregzoll's Avatar
What is this stuff?
As I stated before, Rock-Lathe, Gyp-Rock. Bad part is when you do not keep the dust from going all over the house.
Old 09-13-2012, 07:15 PM   #13
langless28's Avatar
What is this stuff?
The house is circa 1959 so I guess I will send a sample to get tested. I was not expecting this...
Old 09-13-2012, 07:47 PM   #14
gregzoll's Avatar
What is this stuff?
And it will come back as Gypsum, maybe some lead paint, cellulose and nothing else.
Old 09-13-2012, 07:49 PM   #15
langless28's Avatar
What is this stuff?
Well that would be a terrific result! So there's no chance of asbestos? Id rather be safe then sorry?
fuzzy stuff growing on basement floor peggy whiting Flooring 6 11-06-2010 12:46 PM
Am I using the right stuff? davecuz Flooring 2 10-18-2010 11:35 PM
Great Stuff and 6 mil poly vapour barrier maljeff Building & Construction 4 09-30-2010 01:26 PM
Some newer stuff joeyboy Project Showcase 11 01-22-2008 12:14 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 12:21 PM
