What Size Knife? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 11:00 AM   #1
What size knife?
What size knife do you all put your last coat of mud on with on qrywall joints? What about corners? Also, how wide does the topping compound being on say a tapered to tapaered joint, or a non-tapered-to-tapered joint?
Thanks!!!
mopowers is offline   Reply With Quote
Old 02-19-2010, 06:16 PM   #2
DIY staff
Rewards Points: 7,174
Corners--6"
Tapered joints-12"
Butts--16 to 24" ( depends on what it takes to make the seam vanish.)
Old 02-19-2010, 07:47 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by mopowers View Post
What size knife do you all put your last coat of mud......? ..
Mo, As Mike said 6" & 12" should also work for you.
The more experience that you get along with more tools the more sizes you will use, but a 6" & 12" will get the job done.
I recommend Myron's book on drywall. It will more than pay for itself an your first job.
http://www.amazon.com/Drywall-Profes.../dp/B002BWQ54K
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-26-2010, 11:23 AM   #4
Thanks guys! I put the last coat on the walls last night. It turned out a lot better than my other garage I did last year. I don't think I'll have to do much sanding on this one. One more question-
It took 4 1/2 boxes of mud to complete the 2 car garage (22' x 23'). That seems like a lot to me. Does that seem normal to you folks? It was taped when I moved in. All I did was smooth everything out for painting.
Old 02-26-2010, 05:50 PM   #5
Drywall contractor
Rewards Points: 1,070
Seems like a bit much, but if you're happy with the results....mud's relatively inexpensive.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
