Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-13-2012, 10:33 AM   #1
what size drywall to use?
what size drywall would you use on an inside partition wall.
this wall is a load bearing wall that separates the dining room from the living room.
is there a rule of thumb for the sizes to use from inside walls/outside walls and ceilings?
echobravo is offline   Reply With Quote
Old 12-13-2012, 10:42 AM   #2
The walls get 1/2".
Bathrooms get 1/2 but should be water resistant.
I only use 5/8 on the ceiling, but some of the new light weight is rated for up to 24" spans on the ceiling.
I'd rather not have to deal with call back for nail pops or sags that's why I use the 5/8.
The ceiling get done first. Got a lot to do then rent a drywall lift. A lift can really speed things up and make it a whole lot easyer.
Once the ceilings done, install the drywall on the walls sitting horizontal for less seams.
Intall the top piece first so it's tight to the ceiling. The bottom piece is kept 1/2" up off the floor. They sell a simple kicker to aid in lifting the bottom piece or you can just use 1/2 scraps.
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
In wall gutter downspout causing mold on drywall. chrispy35 General Discussion 12 05-06-2011 11:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
