-   -   what size drywall to use? (http://www.diychatroom.com/f101/what-size-drywall-use-166369/)
echobravo 12-13-2012 09:33 AM
what size drywall would you use on an inside partition wall.
this wall is a load bearing wall that separates the dining room from the living room.
is there a rule of thumb for the sizes to use from inside walls/outside walls and ceilings?
joecaption 12-13-2012 09:42 AM
The walls get 1/2".
Bathrooms get 1/2 but should be water resistant.
I only use 5/8 on the ceiling, but some of the new light weight is rated for up to 24" spans on the ceiling.
I'd rather not have to deal with call back for nail pops or sags that's why I use the 5/8.
The ceiling get done first. Got a lot to do then rent a drywall lift. A lift can really speed things up and make it a whole lot easyer.
Once the ceilings done, install the drywall on the walls sitting horizontal for less seams.
Intall the top piece first so it's tight to the ceiling. The bottom piece is kept 1/2" up off the floor. They sell a simple kicker to aid in lifting the bottom piece or you can just use 1/2 scraps.
