What Size Drywall Nails? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 09:39 PM   #1
what size drywall nails?
What size mails should I use for 5/8" drywall in wood studs?
Also, how many are needed to hold a 4x8 sheet? Is there a code?
Thanks!!
mopowers is offline   Reply With Quote
Old 08-20-2009, 09:46 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
Don't use nails, use screws for drywall.
I put my screws in ever 8 inches.
yummy mummy is offline   Reply With Quote
Old 08-20-2009, 10:01 PM   #3
My drill is at my folks' house. And it's only for one sheet I tore out of my garage.
What size should I use?
Old 08-20-2009, 10:07 PM   #4
Registered User
Termite's Avatar
Drywall nails are absolutely fine for use in drywall. I find them easier to "spot" when mudding, compared to screws. Use a dimpled drywall hammer, NEVER a regular hammer.
A 1-7/8" ring shank drywall nail would be the code requirement for walls and ceilings with 5/8" rock. For ceilings I prefer screws but nails do work.
As far as code goes: (per IRC Table R702.3.5)
Walls w/16"oc framing: 8"oc (16" for screws) w/o adhesive
Ceilings w/ 16"oc framing: 7"oc (12" for screws) w/o adhesive
It is a big table with lots of options.
Old 08-20-2009, 10:10 PM   #5
Registered User
Termite's Avatar
Remember, that's the code minimum for spacing. More won't hurt!
Old 08-20-2009, 10:11 PM   #6
Registered User
Rewards Points: 5,482
Be safe, G
Old 08-20-2009, 10:22 PM   #7
Registered User
Termite's Avatar
Be sure to do a really good solid job since this is in the garage. Your garage sheetrock is a very important fire membrane that separates the garage from the remainder of the structure. You definitely need to at least do one coat of mud and tape for fire resistance even if you decide not to sand it and make it pretty.
If you use screws and a regular drill, use caution not to over-sink the screws. If the screw head breaks the paper face of the drywall, consider that screw as not even being there and add one a couple inches from it. Once the paper face is broken the screw can't do its job.
Old 08-21-2009, 05:48 PM   #8
I ended up going and getting my drill I left at my folks' house. I will use screws instead. What size screws do I need for 5/8" rock? Will 1 5/8" get it done. I already have a box of those. Thanks.
Old 08-21-2009, 06:15 PM   #9
Is this the ceiling of the garage?
Habitable space above?
Then 5/8" is all you need
Old 08-21-2009, 07:41 PM   #10
Registered User
Dave, you gotta get that pumpkin off your head, it's affecting your answers!!
Be safe, G
Old 08-21-2009, 07:43 PM   #11
DOH !!
I thought he was asking if (1) 5/8" sheetrock panel would do it
It's the heat - 4th day in a row, only went down to 76/78 in the house last nite
Old 08-21-2009, 08:44 PM   #12
Registered User
Those will work, 12" o.c.
Be safe, G
Old 08-21-2009, 10:45 PM   #13
Thanks for the help!
Old 08-23-2009, 12:05 AM   #14
Registered User
No problem, glad to help, that is why we are here. Until next time, be safe, G
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
drywall question billyg Drywall & Plaster 3 08-01-2008 09:49 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 07:30 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
