What Should I Do ??? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-17-2013, 03:50 PM   #1
Rewards Points: 874
What should i do ???
The Sheetrock butts up against the beam/header ant there is about 3/4" of beam visible and it becomes smaller(almost to where the Sheetrock and beam are flush) toward the end. I don't think corner bead will help. I was gonna Sheetrock the face of the beam but the what about underneath??? Thanks.
What should i do ???-image-2505342120.jpg   What should i do ???-image-2190591655.jpg   What should i do ???-image-3579713598.jpg
Mstrlucky74 is offline   Reply With Quote
Old 12-17-2013, 05:46 PM   #2
Rewards Points: 4,796
If you want to put drywall on the beam, you could cap it with trim.
http://trim-tex.com/product_catalog....egory&catid=15
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Mstrlucky74 (12-19-2013)
Old 12-18-2013, 07:39 AM   #3
Rewards Points: 13,456
Shim the studs out so it will all be even.
