What To Put On The Window Ledge?? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 04:47 PM   #1
What to put on the window ledge??
I got a new window a while back. I am going to put sheetrock around the interior. The question I have about this is what do I put for the base or ledge of the window. Some carpenter told me to put 1/2 or 3/4 " plywood instead of sheetrock and texture it like the rest with corner bead and such. I am not sure if that is right or would plain old sheetrock be the right way to go? Thanks.
ingeborgdot is offline   Reply With Quote
Old 07-17-2010, 10:09 AM   #2
Drywall contractor
Rewards Points: 1,070
I'd use wood. A 1"x of whatever width necessary....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
