What Product To Use To Fill In Gap Between Drywall And Shower Surround - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 11:43 AM   #1
What product to use to fill in gap between drywall and shower surround
I've read to use durabond but also read that it is no longer being made. I haven't seen this for sale at the local lowes or home depot. I would prefer to use a product like this rather than filling in a 1/4 gap with caulk. I have 2 showers that I need to do this do.
RobertN is offline   Reply With Quote
Old 09-09-2010, 11:47 AM   #2
Rewards Points: 558
Well you can use backer rod to fill in the gap and then caulk.
epson is offline   Reply With Quote
Old 09-09-2010, 02:04 PM   #3
Rewards Points: 79
1/4 inch gap, sounds like you can use a trim. Use a good caulk beneath it - probably a couple coats, then using locktite or a similar quick and very strong, water resistant adhesive, apply your trim. There are synthetic trims which are easily modified to fit. -
Of course if this is your place, you might want to use backer rod with joint compound to fill this gap - let it dry well, and use fiberglass mesh tape and skim coat - bringing the wall all the way to the shower as it should be. It's up to you.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-09-2010, 06:32 PM   #4
Phoenix
I have seen durabond for sale at an Ace hardware that we get supplies from very recently.
I have NEVER seen it for sale at Lowe's or Home Depot.
Axecutioner-B is offline   Reply With Quote
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 04:31 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 10:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
