What Is Minimum Spacing For Ceiling Soft Studs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 02:24 PM   #1
What is minimum spacing for ceiling soft studs
I'm building an enclosure around the hvac ducts in my basement and wondered what is the minimum spacing for the crossmembers that hold up the drywall on the ceiling?
toobhed is offline   Reply With Quote
Old 08-07-2011, 02:30 PM   #2
Experienced
Jackofall1's Avatar
I would think more in the line of maximum spacing, given that you usually lay the 2 x 4 on its side to maximize head room spacing at 24" works out well.
Just make sure you leave at least an inch between the hot air supply and any combustable materials (wood).
Mark
Old 08-16-2011, 04:50 PM   #3
Thanks Mark!
Old 08-22-2011, 05:33 PM   #4
Drywall contractor
Rewards Points: 1,070
I'd recommend 16" centers.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
