What Joint Compound To Use? - Drywall & Plaster - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 07:51 PM   #31
Rewards Points: 512
i use the green for taping and for 2nd and 3rd coat i use lafarge rapid coat beige
princelake is offline   Reply With Quote
Old 03-20-2013, 08:31 PM   #32
retired union carpenter
Send a message via Yahoo to coupe
it's just like everything else. it's a learned skill, you begin knowing the basics, you pick up tips from those with more experience, you learn from mistakes made. the simple 4" brush for inside corners cut my inside corner time by at least 1/3, plus sanding time cut 1/2.
a new team of 3 men hanging 12' sheets in a house will beat each other to death, after 3 years together, won't even break a sweat? the more you do, the better you get and easier.
it's only art, if it looks good when done I've never had a problem using USG green lid, other than my own mistakes! it's simply a process you learn for yourself that works for you. consistency,technique, and sequence.
best of luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following User Says Thank You to coupe For This Useful Post:
Nailbags (03-20-2013)
Old 03-20-2013, 08:39 PM   #33
Rewards Points: 626
Originally Posted by ToolSeeker View Post
Must be west coast thing never saw it around here.
That is why it says Pacific North west product only.
Nailbags is offline   Reply With Quote
Is frozen joint compound acceptable once it has thawed? Deck Drywall & Plaster 11 01-03-2013 12:12 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
dots in joint compound insearch Painting 2 06-01-2011 10:44 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
