What To Fill In Large Nail Holes - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 09:11 AM   #1
What to fill in large nail holes
My walls have several large nail holes from where curtain supports used to be. (almost enough to fit my pinky in)
What do I use to fill those holes back in so it will be sturdy enough to reinstall curtain rods?
Thank you!
MangoMelon is offline   Reply With Quote
Old 07-24-2013, 08:58 PM   #2
Rewards Points: 240
is there any wood behind these holes ?
Fix'n it is offline   Reply With Quote
Old 07-25-2013, 07:47 AM   #3
Rewards Points: 6,034
For a hole that big I would use drywall tape (paper tape) to cover the area.
Old 07-25-2013, 07:48 AM   #4
Rewards Points: 4,796
Not sure why "nail" holes would exist. Do you mean screws? I would not be installing curtain rods with nails.
You can't fill it in and expect to put screws back in the exact same spot. Look for studs to screw into, or move the new curtain rods an inch one way or the other, or if you must use the same holes then there's no need to fill them, but get fasteners that tight behind the drywall.
Not these
http://www.naturalhandyman.com/iip/i...i/plastic1.jpg
Something along these lines
http://0.tqn.com/d/homerepair/1/0/F/...lon_toggle.jpg
http://0.tqn.com/d/homerepair/1/5/A/...pandable_3.jpg
http://www.blogcdn.com/www.diylife.c.../img1746rs.jpg
http://0.tqn.com/d/homerepair/1/0/7/...ggle_molly.jpg
jeffnc is offline   Reply With Quote
Old 07-25-2013, 11:33 PM   #5
Ah, thank you for the pics, jeffnc.
Yea, I think I will be making new holes to the side.
Old 08-21-2013, 03:02 PM   #6
Rewards Points: 398
I had the same issue in a guest bedroom - I filled the holes with liquid nails 95% of the way - let it dry, then sparkle the remaining area. I then sanded the sparkle smooth and repainted the section.
For hanging new rods, just raise, lower or shift so it's not being mounted in the same spot.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 08-21-2013, 03:09 PM   #7
Assuming that your spell checker is incorrectly changing "spackle" to "sparkle", I think I actually like that idea.
Old 08-21-2013, 03:12 PM   #8
Rewards Points: 398
What? You don't add sparkle to your rooms?
Damn iPhones...
Old 08-21-2013, 03:20 PM   #9
I was assuming you were not a 12 year old girl, but I have been wrong before....
How to fill in several holes in whitewood pine? TrailerParadise Carpentry 7 04-30-2013 08:23 PM
How to fill in holes before building thin subfloor bighak Flooring 5 02-11-2013 07:43 PM
When I fill the nail holes in my trim there is a little divot left behind hadees Painting 9 02-14-2010 05:32 PM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 07:24 AM
Molding/trim Nail Holes javan Painting 3 06-18-2008 08:53 PM
