What To Do With Drywall Edges In Receptacles? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 09:58 PM   #16
Rewards Points: 6,652
Originally Posted by Techy View Post
its low voltage, put the plate on and forget it's there..
You can't, due to it exposes too much of the gypsum. They would have to place extenders over the holes, to be within compliance.
Old 05-07-2013, 10:06 PM   #17
Sparky
Rewards Points: 510
You're allowed up to 1/4" setback w/ non combustible finish,(314.20).
Techy is offline   Reply With Quote
Old 05-07-2013, 10:27 PM   #18
He has more than that, due to the edges are only 3/8" from the plate.
Old 05-07-2013, 10:34 PM   #19
Sparky
Rewards Points: 510
1/2(4/8) - 3/8 = 1/8..
Old 05-07-2013, 10:42 PM   #20
Go back and look at his pictures. There is more than 1/8" from the front edge of the plate, and the front of the drywall. You can ask him to place a ruler in the hole, to measure the gap from the face of the drywall, and the edge of the lv plate, but I can tell by looking at the pics that they are not correct.
Old 05-07-2013, 11:59 PM   #21
1/8" from the bracket being shallow plus 1/8" from the screw head, so I'm legal. I added washers but I guess the drywall sank into the screw head enough when attached to the stud. I'm OK if I go easy on the mud. I guess people who use 5/8" drywall have to countersink into the plastic.
Dorado is offline   Reply With Quote
Old 05-08-2013, 08:50 AM   #22
Actually that is 4/16's or 2/8's, which is still too far from the edge. If you want to use them, you will need to use box extenders to be in compliance.
Old 05-08-2013, 03:20 PM   #23
Sparky
Rewards Points: 510
314.20 In Wall or Ceiling. In walls or ceilings with a
surface of concrete, tile, gypsum, plaster, or other noncom-
bustible material, boxes employing a flush-type cover or
faceplate shall be installed so that the front edge of the box,
plaster ring, extension ring, or listed extender will not be
set back of the finished surface more than 6 mm (1⁄4 in.).
2/8 = 1/4...
Uneven ceiling drywall issues.... amadogon49 Drywall & Plaster 7 03-25-2013 03:35 PM
Ceiling feature ( drywall edges ) tool man Taylor Drywall & Plaster 2 03-19-2013 10:55 AM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 11:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 05:47 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
