What To Do? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 02:46 PM   #1
What to do?
I was going to install a bath fan in the wall in our bathroom. When I started to open up the wall to place the fan housing, I found that there is 2 layers of 1/2" sheetrock on the walls. This doesn't seem right to me. Since there has been no bath fan in the room, the paint is flaking off the walls in spots and off of the ceiling from the moisture. I have already decided that I am going to replace the sheetrock on the ceiling. Someone did a really shady job of patching an area on the ceiling where the upstairs bathroom had a leak. Anyway, based on what I found with the two layers of sheetrock, should I just rip it all out and take the room down to the studs and sheetrock the whole room? I know it would be easier to leave it and just repair the paint, but I want it to be right. I don't really like that there are two layers of sheetrock on the walls.
mairj40 is offline   Reply With Quote
Old 12-29-2011, 04:18 PM   #2
jproffer's Avatar
Rewards Points: 710
In some cases, 2 layers are required.
What's on the other side of the wall?
A garage, by chance??
jproffer is offline   Reply With Quote
Old 12-29-2011, 04:19 PM   #3
Nope. It's the exterior of the house. There is no garage attached to the house.
Old 12-29-2011, 04:27 PM   #4
jproffer's Avatar
Rewards Points: 710
I wouldn't think a firewall would be required there then. Might ask your local code guy before you lose that second sheet of drywall.
Other than that, it doesn't really hurt anything to leave it if it can be repaired....you lose 1/2" of floor space but that's about it.
