What Is The Color Of Hot-mud When Dry..... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 07:42 PM   #1
Rewards Points: 278
What is the color of hot-mud when dry.....
It's been 3 days since I taped a but joint (one side was butt - other was tapered). The tapered obviously got a thicker bed.
There are some area which I floated a 10" wide taped butt joint as well.
What is the color of hot mud when dry.
It's the weirdest thing...as the edges appear dry as it's *white*, but the center if not even ~thin~ parts of the butt joint look wet in color (a tinge of grey vs white).
I'm skeptical to bed another coat in fear of creating a sandwich.
It surely must be dry now as it as hot mud....that was used. Durabond
Am I going crazy...or could it still be wet inside but it just ~set~ on the exterior.
mobiledynamics is offline   Reply With Quote
Old 11-10-2011, 08:03 PM   #2
DIY staff
Rewards Points: 7,174
You are good to go---
Even in a cold house three days is long enough to wait----You are correct---the mud 'sets' but is still wet for 12 to 24 hours and will slow the drying of the premixed bucket mud if applied to early.
Old 11-10-2011, 09:28 PM   #3
Rewards Points: 278
I hear ya...I just can't explain the coloring of the joint.
Old 11-11-2011, 02:52 PM   #4
DIY staff
Bag mix is gray when dry with whiter edges----that's normal--
Old 11-11-2011, 03:25 PM   #5
Rewards Points: 278
Thanks Mike.
I was planning to get the 80 grit out and start new !
Screw holes are white.
Even the butt side of the tape - they are grey with just the very outer edges being white.
So me assuming white is dry (color of screw heads and feathereded edges), I was thinking something is wrong with the base since it's grey-ish.
The batches are fresh - Sept dates on the bag. Ruled that out.
A call to USG and the rep was telling me to even rip the base out, cause it should be white.
Pics.
Split Yellow / Purple - Butt/Tapered Joint. Fibafuse with Durabond
Purple/Purple - Butt/Butt . Fibafuse with Durabond
Old 11-11-2011, 03:26 PM   #6
Rewards Points: 278
Old 11-11-2011, 09:00 PM   #7
DIY staff
Perfectly normal look---all the different muds have a different shade of white---sometimes the gray mud shows through the whiter top mus and looks bad until it's primed---
