-   -   What is the color of hot-mud when dry..... (http://www.diychatroom.com/f101/what-color-hot-mud-when-dry-123025/)
mobiledynamics 11-10-2011 07:42 PM
It's been 3 days since I taped a but joint (one side was butt - other was tapered). The tapered obviously got a thicker bed.
There are some area which I floated a 10" wide taped butt joint as well.
What is the color of hot mud when dry.
It's the weirdest thing...as the edges appear dry as it's *white*, but the center if not even ~thin~ parts of the butt joint look wet in color (a tinge of grey vs white).
I'm skeptical to bed another coat in fear of creating a sandwich.
It surely must be dry now as it as hot mud....that was used. Durabond
Am I going crazy...or could it still be wet inside but it just ~set~ on the exterior.
oh'mike 11-10-2011 08:03 PM
You are good to go---
Even in a cold house three days is long enough to wait----You are correct---the mud 'sets' but is still wet for 12 to 24 hours and will slow the drying of the premixed bucket mud if applied to early.
mobiledynamics 11-10-2011 09:28 PM
I hear ya...I just can't explain the coloring of the joint.
oh'mike 11-11-2011 02:52 PM
Bag mix is gray when dry with whiter edges----that's normal--
mobiledynamics 11-11-2011 03:25 PM
Thanks Mike.
I was planning to get the 80 grit out and start new !
Screw holes are white.
Even the butt side of the tape - they are grey with just the very outer edges being white.
So me assuming white is dry (color of screw heads and feathereded edges), I was thinking something is wrong with the base since it's grey-ish.
The batches are fresh - Sept dates on the bag. Ruled that out.
A call to USG and the rep was telling me to even rip the base out, cause it should be white.
Pics.
Split Yellow / Purple - Butt/Tapered Joint. Fibafuse with Durabond
Purple/Purple - Butt/Butt . Fibafuse with Durabond
http://www.pingable.net/images/diy/durabond01.jpghttp://www.pingable.net/images/diy/duranbond02.jpg
mobiledynamics 11-11-2011 03:26 PM
http://www.pingable.net/images/diy/durabond02.jpg
oh'mike 11-11-2011 09:00 PM
Perfectly normal look---all the different muds have a different shade of white---sometimes the gray mud shows through the whiter top mus and looks bad until it's primed---
