What Is This Ceiling Material? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 10:44 PM   #1
what is this ceiling material?
My house was built in 1960. One-story, this is the ceiling above my dining room. I had a roof leak so I went to investigate in this area where it was leaking. This board material sits between the drywall and trusses. I've never seen it and was wondering if anyone knows what it is. Those rusty spots are staples that hold in the individual wires running through the board. It feels stronger than a drywall board...almost like a concrete.
Any help is appreciated.
jettamadnesa is offline   Reply With Quote
Old 03-16-2014, 10:58 PM   #2
Rewards Points: 13,260
At one time that house had in the ceiling heat.
One of the silliest ideas in building history.
Heat rises, makes for nice warm ceilings nothing else.
Is it still working? Most people have gone to a different system years ago for heat when it fails.
Old 03-16-2014, 11:05 PM   #3
That would make sense. In each room there are "temperature dials" and we never knew what sort of heating that would control. They look cool but are of no use anymore...HVAC now. I was just a little worried since I will be cutting out a pretty good area there to fix. Do you know if that stuff is difficult to cut through?
Can you tell me if there is a name for that stuff? I'd really like to research it just to learn more.
Old 03-16-2014, 11:14 PM   #4
Is it bad or just the sheetrock that needs replacing?
Have you been in the attic and removed the insulation and trashed it?
100% sure the circuit that powers that old wiring has been disabled?
Sir MixAlot (03-17-2014)
Old 03-17-2014, 08:07 AM   #5
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
I despise ceiling heat like that, so does the fire dept. Had a fire at an apt complex several years ago, the fire fighters were doing the standard open ceiling action and they got tangled in wire. Needless to say I had to identify every building that had this stuff.
Might be a good idea to let your local FD know about this.
gmaint is offline   Reply With Quote
The Following 2 Users Say Thank You to gmaint For This Useful Post:
Gymschu (03-17-2014), Sir MixAlot (03-17-2014)
Old 03-17-2014, 08:24 AM   #6
Good point g.
In some cases the roof needs to be vented in a fire to lower the temp. and get rid of some of the smoke.
You make a hole in the roof then have to punch through the ceiling with a Pike pole. Going to be fun busting through that stuff. Someone's going to loose a pole.
Ceilings need to be pulled down to check for hidden fires.
The good thing is with two layers like that the fire would be more likely to stay in that one room if someone closed the door before running out.
ceiling material for old 12 foot ceiling homes built in 1915 jeanne starr Carpentry 4 09-06-2010 10:44 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
bathroom ceiling material? mayhem69 General DIY Discussions 1 12-26-2008 06:09 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
