What Are The Advantages Of Skim Coat And Primer? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 10:30 AM   #1
What are the advantages of skim coat and primer?
I'm finishing up the drywall in my bathroom and I am pretty satisfied. I am not a pro so there are some spots where it could be better (a couple of divets nothing major). Should I skim coat or would a good primer give it an even appearance?
fortunecookies is offline   Reply With Quote
Old 02-10-2011, 10:39 AM   #2
Experienced
Jackofall1's Avatar
Paint will not cover irregular surfaces, and a bathroom usually painted with semi-gloss will amplify those irregular surfaces.
Mark
Old 02-11-2011, 04:04 PM   #3
Drywall contractor
Rewards Points: 1,070
Agreed, any type of gloss, semi-gloss, "satin" paint is not your friend. Fill all voids prior to paint and use flat paint if possible...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-11-2011, 07:09 PM   #4
The areas that I'm speaking of are not horrific. I can notice them because I am the one who did it. But I don't think the average person will notice. I just want the walls to look smooth and I would like to know if primer and/or skim coating would be best. I don't want the paint to be soaked up by the drywall. I'm not trying to disguise anything I just want to know which one or (if both) looks best.
Old 02-11-2011, 10:56 PM   #5
Drywall contractor
I'd touch up then paint. You'll know the spots are there, so you might as well fix 'em....
The Following User Says Thank You to bjbatlanta For This Useful Post:
fortunecookies (02-12-2011)
Old 02-12-2011, 07:07 AM   #6
Rewards Points: 530
Do the mud touch up then use a high build primer before painting.
The Following User Says Thank You to boman47k For This Useful Post:
Old 02-12-2011, 07:19 AM   #7
Rewards Points: 530
Primer/sealer prevents this and equals out the porosity of the walls to make for an even finish.
fortunecookies (02-13-2011)
Old 02-13-2011, 06:15 PM   #8
Household Handyman
Rewards Points: 1,408
I knew an older painter for years before he passed away. He did a lot of new high-dollar homes and one trick he taught me was to have the primer colored. If you were going to use a light color-he used a yellow, a medium color--he used blue or green, a darker color-he used brown or even black. Not this was just a small shot of color added at the paint store. When he put it over newly finished rock it would show the imperfections from skimming the rock by shining a bright light flat to the wall or ceiling. This has worked well for me in repairs, as I'm not the best at patching small areas.
The Following User Says Thank You to Thurman For This Useful Post:
Skim Coat Tools? Knives, Trowel, or Magic Trowel?? Lovegasoline Building & Construction 7 08-01-2012 10:25 PM
PVA Primer Disaster bobcatm Painting 1 08-17-2010 12:41 PM
Kilz Latex Primer & Aura Finish Coat? HenryG57 Painting 7 06-02-2010 03:41 AM
Primer - even coat needed? DaveSD Painting 7 05-10-2010 03:40 PM
Skim Coat bigfixer Painting 8 02-23-2010 11:42 PM
