Wet Sheet Rock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 04:18 PM   #1
wet sheet rock
should I remove wet sheet rock from baseboard area or let it dry and then replace baseboard? The same room has flooded several times, but now it is fixed. sheet rock is soft about 6 inches up from floor.
amy@jccturf.com is offline   Reply With Quote
Old 06-09-2010, 08:25 PM   #2
Phoenix
I would remove the sheetrock & replace it with new, the old stuff will never be strong, will probably warp & bubble, & could or does have mold now.
But before I replaced the sheetrock i would FIX THE LEAK
I have no good advice for the concrete.
Axecutioner-B is offline   Reply With Quote
Old 06-10-2010, 11:38 AM   #3
Handyman
Rewards Points: 512
I would just cut the drywall up about a foot and replace it. One sheet will allow you replace 32 ft. Or you cut 8" up and one sheet will allow you to replace 48 ft. Remember to keep the new drywall at least 1/2" above the floor. Oh, and while the old drywall is off, mark the stud locations...makes it easier for nailing the baseboard back on.
canadaclub is offline   Reply With Quote
Old 06-10-2010, 12:05 PM   #4
WaldenL's Avatar
Rewards Points: 268
I'd let it dry, and then replace it. Wet rock is a royal pain to work with, let it dry out and the cut and replace.
WaldenL is offline   Reply With Quote
Old 06-10-2010, 06:43 PM   #5
kwikfishron's Avatar
Rewards Points: 82
Absolutely replace it and any insulation that also might of got wet.
The last thing you need is a mold invasion.
kwikfishron is online now   Reply With Quote
Old 06-11-2010, 03:10 PM   #6
Drywall contractor
Rewards Points: 1,068
Definitely replace the rock. It's a pain to try and finish a joint near the floor and get i looking right. You might want to consider replacing up to the 4' tapered joint. Drywall's not that expensive and you'll have to repaint the whole area anyway...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Axecutioner-B (06-12-2010)
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 01:46 PM
Sheet rock (1/4") in trailer house sagging chrissygarden Building & Construction 4 08-19-2009 11:53 PM
sheet rock screw size? Vermont1 Roofing/Siding 1 04-07-2009 09:58 PM
Painting over messed up sheet rock. emilyiam Painting 2 03-24-2008 05:00 PM
What size sheet rock for garage ceiling? Billy Boy General DIY Discussions 12 01-24-2008 01:36 PM
