Wet Sanding New Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 11:35 AM   #1
Rewards Points: 422
Wet sanding new drywall
Is it easy to do for a beginner? Any negatives? We need to sand an 18' X 18' ceiling in my daughter's basement, including 2 soffits. The main reason would be to keep the dust down. Thanks.
Jim McC is offline   Reply With Quote
Old 02-03-2014, 11:40 AM   #2
Rewards Points: 13,250
Makes more of a mess of what your sanding to me.
See your local Home Depot or construction rental places rents drywall sanders.
http://www.coastaltool.com/a/port/78...all_sander.htm
Old 02-03-2014, 01:33 PM   #3
Rewards Points: 5,974
I'm not exactly a beginner but I never got it to work for me where I was happy with it.
Old 02-03-2014, 09:18 PM   #4
Professional
TotalHomeworx's Avatar
You have to be really good at drywall so that you would need limited sanding between coats and final coat in order for you to replace the dry sanding with wet sanding. It's a lot of extra drying time. Vacuum sand it and tarp off the area you a working in will be faster.
TotalHomeworx is offline   Reply With Quote
Old 02-03-2014, 10:39 PM   #5
Rewards Points: 422
Thanks. You talked me out of it.
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Sanding drywall using a power sander? gone_fishing Remodeling 3 03-14-2009 08:20 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 10:08 PM
Sanding a drywall ceiling? kcrossley2 Drywall & Plaster 7 01-01-2009 10:44 PM
