Weird Texture Crack - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 10:50 AM   #1
the Musigician
DangerMouse's Avatar
Weird texture crack
I had a wall taped and mudded (horizontally) for weeks before I had the time to put texture on it, the seam was sanded smooth and had no cracks. The very next day after texturing, a hairline crack appears straight along the seam!
What gives? I have no cracking problems with the vertical seams anywhere I've done. Why only the horizontal seams and why wasn't there a crack until I textured?
Any ideas anyone? Can I patch them invisibly?
They'll come back, right? LOL
DM
Old 12-13-2010, 10:03 AM   #2
the Musigician
No-one has seen this before? Anyone?
DM
Old 12-13-2010, 10:34 AM   #3
is it an outside wall?
The older I get the better I was
Old 12-13-2010, 10:46 AM   #4
the Musigician
Nope, interior.
DM
Old 12-13-2010, 10:51 AM   #5
the Musigician
It's all 4 sides interior walls even.
DM
Old 12-13-2010, 10:53 AM   #6
vertical seams have backing continuous where as horizontal is layed across stud spacing. If this is a new event and you have textured this way before? all that comes to mind is amount of tape bedding material may be light and humidity levels may affect moisture absorption rates creating stress crack. just a thought
Old 12-13-2010, 11:04 AM   #7
the Musigician
It's just weird that the seam fill did not crack for weeks! Just after I added texture! THEN it cracks???
Any fix? fill and smooth a bit to try to hide it? It'll just crack again, right?
Maybe I'll do wood panel and wainscot wood trim over that point.
DM
Old 12-13-2010, 03:21 PM   #8
i had exactly this happen with a new ceiling i hung. rocked it, taped it, let it sit for a few weeks before texture, then, when it's textured i get hairline cracks. i partly blame the fiberglass tape that was used. all the rooms that were paper taped did not have this issue. however, the other likely cause was the topping compound shrinking when drying. i sanded the texture off one crack. caulked a small area, it's holding, also used setting compound in another area, it's holding as well. if the setting compound holds till spring i'll fix the ceiling cracks with it.
racebum is offline   Reply With Quote
Old 12-13-2010, 04:40 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you use mesh or paper tape? I have heard of many more problems with cracks for whatever reason with mesh tape than paper tape. Paper tape actually adds a structural benefit to the joint by resisting shifting between the two pieces of drywall that the mesh does not.
Old 12-13-2010, 07:34 PM   #10
Did you prime before texturing?
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 12-13-2010, 08:37 PM   #11
Registered User
Rewards Points: 5,498
Bingo! Prime is required before and after texturing: http://gypsum.org/pdf/GA-216-2010.html
pp.264, #2: The paper and mesh held about the same with the paper hiding the movement better (thin crack) and the mesh flaking the finish due to compression with the racking test. http://www.curee.org/projects/EDA/do...A03-public.pdf
Gary
Old 12-14-2010, 07:19 AM   #12
the Musigician
Thanks for the input guys. I guess I'll just do wood over the crack.
I sort of wanted to do that anyways, this just clinches it. Po)
DM
Old 12-14-2010, 09:11 AM   #13
Most textures (if not all) are applied wetter than the finishing compound, therefore shrink more. When texture is applied to unprimed compound it tends to soak in to the finishing compound and dry from both sides, thus shrinking the finishing compound, pulling on the tape and cracking. Applying a prime coat equalizes the surface porosity and helps the texture dry to the outside.
I am sure that thousands of homes have been textured without priming first with no problems. However, priming first will help prevent cracks.
Old 12-14-2010, 09:22 AM   #14
the Musigician
So, I guess if I had primered just that area, it would have prevented this? hmmm.... Luckily, I can go about this two ways.... I can re-texture just the cracked area with the "Upside-down Fire" design I'm using in there as it hides easily and be pretty sure it won't re-crack, orrrrr add a 'chair-rail' trim all around the room to cover it, which may not be such a bad idea after all as that and the baseboards will prevent any cabinet/towelstand contact with the walls. It's only a 5'x5' minibath and the only room I'll be doing this in.
Now to decide....
Thanks for all the input guys!
DM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 10:03 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
