Weird Drywall - Dual Layers Of 3/8's? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 08:10 PM   #1
Question
Weird Drywall - Dual Layers of 3/8's?
Hello all,
I had to repair some drywall in my kitchen due to a leak, and I found something pretty weird. All of the drywall in my house is double layered 3/8" drywall, which appears to be made up of 2' x 8' (maybe closer to 1.5' x 8') sheets. The drywall for the most part is white, with regular brown paper backing. Any idea what this stuff is? Oh, and the house was built in 1957.
suprvee is offline   Reply With Quote
Old 12-06-2010, 08:10 PM   #2
Ah shoot, and I posted this in the wrong forum. Grr
Old 12-07-2010, 05:55 AM   #3
That's called rocklath. It is 3/8 something similar to drywall and a plaster top coat. It was common after wood lath plaster. It was the predecessor to blue board.
Old 12-07-2010, 07:07 AM   #4
the Musigician
DangerMouse's Avatar
"Nuttin' up my sleeve... *PRESTO!*"
You're in the right section!
"But Bullwinkle, that trick NEVER works!"
DM
Old 12-11-2010, 06:28 PM   #5
Hello all,
It is rocklath and you'll find it is extremely strong and extremely hard. It will dull your sheetrock saw in minutes. Go to the depot or lowes and get a special blade for your sawsall. The blade has grit instead of teeth and will walk through it like it was butter. It will also last forever.
dadflynn is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
