Water Damage: Repairing Ceiling Drywall Defects at Seams?
I’m a long-term tenant in an apartment where the owner installed a new drywall ceiling as part of a larger construction job (building is from 1920’s and previously had all metal lathe/plaster ceilings & wood lathe/plaster walls).
A few months later, the steam radiator valve exploded in the apartment above and I could hear the water gushing: then I could see some of the ceiling drywall seams swelling and water started to drip down through one area? After the leak abated and dried, there are now two types of defects present in the ceiling drywall:
1) A fine crack of approximately 4’ running along one of the drywall seams.
2) The seam of another drywall joint, approximately 5’ long, is swollen and bulging slightly but isn’t cracked.
I’m more familiar repairing plaster defects than with drywall, which is sort of new to me. After the construction I sent a lot of time restoring this room and skim coating it. Except for these new defects, the ceiling is a beautiful and spotless flat plane….I’d like to keep it that way. The owner’s workers will come in to repair the ceiling defects, but honestly these guys are monkeys who don’t care about the appearance of their work (or don’t know how to do it correctly). I wouldn’t be surprised to see huge mounds of drywall slapped over the seams.
Question: How best to perform the repairs to these two type of drywall defects? I’d like to provide some guidance, and if need be, intervene.
Thanks a bunch!
