Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-14-2011, 01:41 PM   #1
Water Damage Advice Please!
Hi Guys,
I moved into a new apartment and I now noticed there are some water stains and what looks like a sagging ceiling? I do not know anything about this. Is it safe to have this in the ceiling? Any advice on what I should do? THANKS!
flyinglotus is offline   Reply With Quote
Old 08-14-2011, 01:46 PM   #2
Tileguy
Bud Cline's Avatar
Yup. Water damage.
"Is it safe" how? What's the question?
Old 08-14-2011, 01:50 PM   #3
Originally Posted by Bud Cline View Post
Yup. Water damage.
Is there a possibility that it can cave in? Does mold form quickly?
Old 08-14-2011, 02:33 PM   #4
Tileguy
Bud Cline's Avatar
Water probably from a leaking roof has found its way to the seams in the drywall and of course has stained
the areas it traveled in. No signs of any moisture at any of the other nails that hold the board in place.
Can't tell about warping from the photos but it appears to be solid and in fair shape. It is really impossible
to know for sure based on a photo on the Internet.
What does the landlord have to say about it?
Mold? That's a different story. Could easily be mold on the other side.
Old 08-14-2011, 07:49 PM   #5
The swollen tape and sagging s/rock is from the water damage as you already know. Judging buy the extremely crowned and visible spackle on the joints I'd say this area has been repaired before by a not-so-fussy repair guy in the past. Looks like you will need new rock again; sagging rock will give in to gravity eventually. Be advised that sagging means it has pulled away from the frame creating a gap between rock and frame. This means the fasteners are no longer doing their job and the tape is beginning to support the weight. Only a matter of time before the sheetrock is in your soup. Call your landlord and ask him for the phone number of the local health and safety board. He'll get your drift.
maxsmoothwall is offline   Reply With Quote
Cement cracks in foundation after water damage Ginette Building & Construction 4 09-06-2010 07:14 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Need some advice on buying home termite & water damage. Mr Heshup General Discussion 1 03-29-2009 04:06 PM
Cabinet water damage (pics)- any advice? Asma Carpentry 5 12-05-2008 08:15 PM
