Warped Sheet Rock - How To Repair? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 08:58 AM   #16
Rewards Points: 1,654
Originally Posted by princelake View Post
ahhhh a fresh coat of paint and some chaulking in the crack will make it look good as new
It's caved in pretty bad. If I push my hand on the wall there it yields, meaning it is still wet.
miamicuse is online now   Reply With Quote
Old 07-01-2012, 11:58 AM   #17
Rewards Points: 512
i was kidding! your going to have to wash that down with some mold control(you can buy it at home depot) then rip out the wet drywall and go farther then you think unless you have a penatrating moisture meter. and go as far as it says cutting it off where ever your studs are or as you say furrinng strips cause its block wall. then spray and clean down the area with mold control again. then you'll have to move the counter or do some tricky drywall work. mud the patch, sand out and prime the area. then paint the wall.
princelake is offline   Reply With Quote
Old 07-01-2012, 02:17 PM   #18
Rewards Points: 190
With the dishwasher pulled and a gap between the counter and the wall, I see no reason why you can't slide in a single piece of sheetrock and secure it properly to the furring strips. No need to remove the countertop. Add matching backsplash and you are done.
zircon is offline   Reply With Quote
Old 07-03-2012, 09:04 AM   #19
All, thanks for all the helpful replies.
My mold test came back and the results are "ELEVATED". I started a new thread in pest control forum as it's more appropriate there.
Moisture Penetration and Mold Advice Needed
I wanted to keep this thread for the sheet rock repair problem but thought if anyone were interested in the mold inspection I posted it there. Thanks.
hanging sheet rock . glenn_s60 Remodeling 5 03-29-2012 06:19 PM
Patio river rock loose stone repair louschuen Flooring 0 12-08-2011 04:50 PM
Glue on sheet rock barbarajones Painting 4 06-18-2011 10:35 PM
metal paint on sheet rock joeyc Painting 2 04-18-2011 04:04 PM
Sheet rock paper came off JEDI RAIN Drywall & Plaster 4 03-09-2011 09:56 AM
