Warped Drywall Can I Use It - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 09:32 AM   #1
warped drywall can i use it
Hello all, today I had the lumber co. deliver some 4x8x1/2 drywall to my house while I was at work.When I got home I noticed that they must have given me all their warped sheets lying around. So my question is, will the warped drywall return to normal once I screw it to the walls or will it be noticeable? FYI my studs are 2x4 and are spaced on 16" centers. Thx
devilleather is offline   Reply With Quote
Old 10-26-2010, 03:22 PM   #2
how warped? if it's wavy it will never be the same. if it's just bowed but otherwise flat you'll be fine.
racebum is offline   Reply With Quote
Old 10-26-2010, 08:34 PM   #3
ok thx, yea its wavy at the top.
Old 11-07-2010, 10:11 AM   #4
Drywall contractor
Rewards Points: 1,070
If it's not all warped, lay the warped pieces flat on the floor and put the good pieces on top. The weight should flatten out the warped sheets in a day or two...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-09-2010, 06:55 PM   #5
[quoteif you can read this in english, thank a soldier. Support our troops.][/quote]
ooh rah!!
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
