Want To Take Out Plaster In Stairway - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 05:51 AM   #1
Rewards Points: 156
Want to take out plaster in stairway
I have a hundred year old house. Most of it was remodeled years ago and the plaster was replaced with drywall. There are a couple of areas where there is still plaster though - 2 closets and the stairway to the basement.
I have noticed when putting in some recessed lights that there's lath boards in the ceiling. Was it pretty standard to leave the lath when taking out plaster to put up drywall?
I want to remodel my 2 closets and redo the stairway because the plaster looks old, is cracked, and just isn't very attractive. Would I want to leave the lath boards?
I have never done this before but I have found a lot of information online and I think it could be a great learning experience for me.
strategery is offline   Reply With Quote
Old 02-06-2013, 06:01 AM   #2
DIY staff
Rewards Points: 7,174
It is seldom left----one reason to leave it might be the different thickness of the plaster or drywall--
Some times wood furring strips are needed to bring the studs out so the drywall meets the window and door jambs properly---
It's a messy job,so plan on adding a good vacuum cleaner and face mashs to your shopping list.
Old 02-06-2013, 10:28 PM   #3
Rewards Points: 142
get the good face mashs, they have little vents on the front. they work a lot better than the cheap ones.
Fix'n it is offline   Reply With Quote
Old 02-08-2013, 03:27 AM   #4
Rewards Points: 156
Do the lath boards ever have any structural support? Or can I just yank them all out?
Old 02-08-2013, 05:41 AM   #5
DIY staff
Just yank them out----A 2x4 or two might be needed when adding the drywall---some times the wall framing is missing the corner nailers--
Old 02-08-2013, 08:41 AM   #6
Rewards Points: 12,856
An old house like that used rough cut studs and there almost never perfectly flat or even across the whole wall.
Just use a piece of brick string to check to see if they need shimming, sistering, plaining.
If not your going to end up with a funky looking wall.
Old 02-08-2013, 10:31 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
And sometimes they shimmed the lath because the stud was really under sized and I have seen lath notched because the stud was too thick. Most times back in the old days they didn't space on 16 centers, there was no need to. The use of 4X8 sheet goods brought into play the 16 center line rule.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-08-2013, 11:47 PM   #8
Rewards Points: 156
I'm not quite knowledgeable enough on the terminology to follow what you guys are saying.
I may have to hire someone for this job if it is going to be complicated. I could however save some time by doing a lot of the demolition myself, right?
Also, is there any suggestions on what to do with the lath boards and plaster? Is this likely to have asbestos in it?
Thanks everyone. I really appreciate your feedback and guidance!
Old 02-09-2013, 07:38 PM   #9
DIY staff
You will find lead paint but seldom asbestos---
Good respirator---fans in the window---and plastic sheeting to keep the dust confined---
The demo can be expensive--doing that yourself will save you money.
Old 02-10-2013, 10:53 AM   #10
Rewards Points: 142
Originally Posted by strategery View Post
I
not complicated, but lots of work. get friends !!!
save time = maybe, but probably not. contractors "been there, done that", so they will get it done faster, if/when they get there. but LOTS of friends will save you a lot of time.
when you must it down, it will mostly separate. plaster in the garbage. i burned my lathe.
outside corner -- plaster meeting exposed brick amakarevic Drywall & Plaster 0 12-29-2012 04:03 PM
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 09:28 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
