Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-26-2012, 04:30 PM   #1
JOATMON
ddawg16's Avatar
Walls - What to Put At The Bottom?
I'm reading here that you should leave about a 1/2" gap between the drywall bottom edge and the floor.
My existing house has a strip of wood below the drywall (Old lap & plaster).
Some of the rooms will be getting carpet...some ceramic tile...some hardwood....
All the walls will be getting 5/8" type X drywall....
So....do I leave a gap? Or do I put down a new strip of wood = new drywall thickness?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-26-2012, 04:41 PM   #2
Looks like your floor is flush with the top of the bottom plate? May need to add 2x4 (whatever wall thickness) blocks between the studs to provide backing at the bottom. Then keep the drywall up the 1/2" off the floor.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
joecaption (11-26-2012)
Old 11-26-2012, 04:53 PM   #3
JOATMON
ddawg16's Avatar
Original sub floot is 1x6's.....bottom plate is on that.....
This room originally had solid oak flooring....when I repaired the bathroom floor I had to yank up all the hardwood (some was damage by pets from the PO)
Once the floor was repaired, I put down 3/4" plywood with carpet over that...now the carpet is gone....and I'll be putting back down the solid oak floor (yea, I saved the good wood).
So...my sub floor is about 3/4" from the top of the plate...I can't leave that strip down....the old wall was about 3/4" thick...the new will be 5/8. I guess I'll need to drop a strip of wood into the gap left by the old firring strip...add the blocks as you suggested...and do the 1/2 gap.
Next question....exactly what is the reason for the 1/2 gap?
My
and
Old 11-26-2012, 06:33 PM   #4
Super Moderator
Nothing--air---
Install the upper sheet first---cut the bottom sheet to give you about 1/2 inch---use a drywall jack (kicker) to lift the sheet and screw it in----
Old 11-26-2012, 06:47 PM   #5
Floors are never level or perfectly flat. If it was tight the the floor you would have to fight every piece to get it in place.
mae-ling (11-26-2012)
Old 11-26-2012, 06:59 PM   #6
That and it keeps it up off concrete and moisture issues.
Old 11-26-2012, 09:13 PM   #7
Moderator
You don't need backing at the floor for the drywall (doesn't require fastening -or support, in any framing perpendicular to wall framing), but I would use it to seal the thermal envelope against air infiltration/exfiltration on the exterior walls at the drywall, per minimum code; http://publicecodes.cyberregs.com/ic...002_par021.htm
ADA the drywall, for both heating and cooling; http://www.buildingscience.com/docum...wall-approach/
Are faced batts required in your Zone 3?
Gary
Clothes taking longer to dry?
Old 11-26-2012, 09:31 PM   #8
If for any reason there is a flood or leak the water can't wick up in the drywall until it gets at least 1/2" deep thus saving you from having to replace the drywall. Not as important but your carpet guys will love you too.
Old 11-26-2012, 11:34 PM   #9
automated tool pro
I like ohmikes answer to the gap question. It's just space to move the boards around. if the wall was framed too short you'd have no room to move the boards around and put them in place.
drywallfinisher is offline   Reply With Quote
Old 11-27-2012, 01:36 AM   #10
JOATMON
ddawg16's Avatar
It all makes sense now....thanks guys...
My
and
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 04:17 PM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Bowing Walls - Pony Wall DoItMyselfToo Building & Construction 0 02-24-2011 12:21 AM
