Walls And Ceiling In A New Bathroom - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 07:42 AM   #1
Walls and Ceiling in a new bathroom
Hi there,
Looking for some information on finishing the walls and ceiling for a tub/shower.
1) I have Durock cement board on the walls of the shower (I am installing tiles), and I'm not sure what to use for the ceiling - regular drywall, water resistant or Durock?
2) How do I finish the joints at the walls to ceiling if I'm using different materials?
Any input is appreciated!
MCath is offline   Reply With Quote
Old 03-09-2013, 07:56 AM   #2
DIY staff
Rewards Points: 7,174
Standard drywall or green board are fine---unless it's a steam shower.
Tape in the usual fashion-- Just enbed the tape in the wall /Durrock portion and finish coat the ceiling---
Old 03-17-2013, 03:55 PM   #3
Drywall contractor
Rewards Points: 1,070
Or just run your tile tight to the ceiling and run a bead of caulk. You'll still need to "spot" the nails around the perimeter of the ceiling. And agree that either type of drywall is fine as long as properly painted.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-17-2013, 11:40 PM   #4
Registered User
Rewards Points: 4,912
Green board (1/2") requires 12"oc ceiling framing, no vapor barrier or retarder (resembles cottage cheese years later...);http://publicecodes.cyberregs.com/ic...002_par013.htm
Gary
Gary in WA is online now   Reply With Quote
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
Bathroom ceiling and walls HELP! Maia Painting 13 02-21-2013 04:21 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Bathroom Walls and Ceiling Become Cracked and Hazy ChantillyScott Painting 2 03-02-2010 02:20 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 04:32 PM
